Old 07-24-2005, 07:28 PM
Default Muncie Speedo Gear Question
What combination of speedometer gears would be correct for a 69 Camaro with a Muncie 4 speed, F70-14 tires, and 4.10 gear ratio. The Rick's catalog states that the driven gear should be green with 22 teeth but does not give a matching driver gear. What would be the correct color driver gear and number of teeth?
Thanks, Paul
Attachments - The Supercar Registry 150528-DSCN0489.JPG 150526-DSCN0488.JPG 150523-DSCN0487.JPG
Old 07-24-2005, 08:35 PM
Default Re: Muncie Speedo Gear Question
I thought it should be Part #3860348-Orange with 25 teeth?
Old 07-24-2005, 08:57 PM
My tranny currently has an orange driven/white driver gear and came factory equipped with a 4.10 axle ratio. The original owner installed 4.88's and drag raced the car for several years but before I bought the car the original 4.10 gears were reinstalled. Maybe the speedo gear is OK.
The Rick's catalog must be incorrect then.
Paul
Old 07-24-2005, 09:16 PM
Don_Lightfoot's Avatar
It wasn't mentioned, so you may have it. I believe the 4.10's with four speed also had an adopter (or whatever it was called) between the cable and tranny gear. My Camaro assembly manual is loaned out right now otherwise I could find the proper name.
Specialized Chevrolet Decals
Old 07-24-2005, 09:35 PM
Kurt S Kurt S is offline
Some 4.10 cars have it, some don't. Depended on which trans part # they got.
Kurt S - CRG
Old 07-25-2005, 12:20 AM
69L78's Avatar
69L78 69L78 is offline
My car has the M-21 with 4.10 posi and has the adaptor.
