Old 07-18-2005, 03:50 AM
John's Avatar
John John is offline
Default 1969 chevelle 396/375 aluminium head....
How many 1969 chevelles with 396/375 motors came with aluminium heads? ...and would the heads be the "842" casting # ?
Old 07-18-2005, 04:27 AM
John's Avatar
Default Re: 1969 chevelle 396/375 aluminium head....
...while your looking that up...
...would the intake casting nymber
...be the "163" aluminium intake?
Old 07-18-2005, 06:42 AM
*How many 1969 chevelles with 396/375 motors came with aluminium heads?-400,& that includes Elcamino
*and would the heads be the "842" casting # ?-Yes
*would the intake casting nymber be the "163" aluminium intake?-Yes
Old 07-18-2005, 07:53 AM
John's Avatar
....The reason I am asking is because I just picked up
..a 4-bolt main block with this casting # 3935440
...and on the front pad is T0824KG
....I'm going to look for more numbers on it tomorrow
Old 07-18-2005, 08:04 AM
I would like to know what you find the casting date to be,down by the Freeze plug/starter motor.
Old 07-18-2005, 08:09 AM
John's Avatar
I will check that also....
Old 07-19-2005, 04:33 AM
John's Avatar
..after further review of the block
...the casting date on the side of the block is
..... G11 8
....and there is a vin # on the side of the block that reads
........ 18BXXXXXX
...so I believe this to be from a 1968 two-door sedan chevelle ( baltimore built )...probably a 4-speed ( post ) car
.....the numbers on the front pad are definately
.... T0824KG
...YYYYEEEEHHHAAWWWWWW!!!!!
Old 07-20-2005, 02:25 AM
John's Avatar
.....I just double checked the casting numbers, the numbers on the front pad , and the vin number....
..and saw that I had "MIS-READ" THE block casting date!!!!
...the Date on the block is " C 11 8 "....NOT "G 11 8"....WHICH MAKES THIS A MARCH, 11TH 1968 BLOCK
....I will send some photos later
Old 07-20-2005, 05:00 AM
That makes a lil more sense.But that mid May 1968 VIN# vs. the August 1968 Tonawanda engine assembled date is hard to swallow.
Are you sure that Tona date isn't T 03 24?
Old 07-19-2005, 04:37 AM
John's Avatar
...So how many 1968 chevelles came with aluminium heads?
