Old 05-24-2005, 02:30 AM
blue thunder blue thunder is offline
Default Muncie Transmission
Hey Guys does anyone have any information on this Muncie transmission? These are the numbers that are stamped and cast on the unit that I have in my inventory. Housing casting 3885010, tailstock casting GM 3846429, and shift cover plate casting 3884685. The stamped numbers are P7E29 and 7R29599. If someone can help me identify this tranny with more specs I would greatly appreciate the help.
Thanks, Alan
'70 Deuce
Old 05-24-2005, 03:26 AM
Default Re: Muncie Transmission
Alan,
P7E29:
*P=Muncie
*7=Year,1967
*E=Month,May
*29=Day
7R29599:
*7=year,1967
*R=Arlington Tx. is Vehicles Ass. Plant.-They only built BIG Cars.-This is from a Passenger car,Impala,Caprice,etc.
*29599=Unit VIN #,are you sure there isn't a digit missing here? It should have 6 digits.
(I think only the M20 Muncie was possible for the 1967 BIG passenger cars,so this is an M20 Muncie originally.)
*Maincase #3885010 used on ALL Muncie M20-M21-M22 1966-67 Cars.
*Side cover #3884685 used on Same.
*Ext. Housing #3846429 used on ALL Muncie cars until 2/65 I thought.Does it look authentic to this particular Trans.?
Rick
Old 05-24-2005, 03:48 AM
Everything appears to be original to the transmission, so I think that it is correct. Could it be that this tranny came from a GTO? Many thanks for your reply, Alan
Old 05-24-2005, 03:50 AM
Rick,
Those were all of the VIN numbers that I could read from the case.
Old 05-24-2005, 04:15 AM
mockingbird812's Avatar
Thanks, Alan
'70 Deuce
I think there shld be another number in front of the "7R29599" to designate the division of GM, i.e. 1 is Chevrolet.
Sam
Sam...
Old 05-24-2005, 04:29 AM
Yep..That's true Sam.
Arlington built Chevrolet(1)-Pontiac(2)-Olds(3)
And they all had 6 last digits in their VIN#.Arlington didn't start numbering with the 200001 series until after Jan.1970.
7R29599
Alan can you see anything in front of the 7 & after the R?
Old 05-24-2005, 05:24 AM
Guys,
I did some cleaning in this stamped area because it is a little scruffy and it looks like the letter after the 7 is a letter F. Does that make sense? There doesn't appear to be any other stamping before the 7 or after the F, other than the numbers shown in my first posting. What do
you think?
Old 05-24-2005, 06:45 AM
crash crash is offline
Plant designation didn't start until the 1968 model year, and the 429 tail housing was used thru the 1970 model year in Pontiac A-body's...Hope this helps...Crash
Old 05-24-2005, 07:48 AM
Found this in the site below for what it is worth:
"Beginning in 1968, the car's last eight numbers of the VIN were stamped on the transmission. As with all car productions there are exceptions to the rule. One good source has a late model 1967 GTO with the VIN stamped on it. "
<font color="red"> GTO Alley </font>
Other useful info found on this site too.
Sam
Sam...
Old 05-24-2005, 06:41 PM
I will give a look at this information to see if I can de-code some of it.
Alan
