Old 03-17-2005, 05:35 PM
rsatz28 rsatz28 is offline
Default Ceramic Coated Headers - Clean Up
I'm taking off the existing Flowmaster exhaust system and am putting the American Thunder series back on the car. I want/need to refurbish the headers. Can I polish the headers? If so, with? Thanks.
Rob
69 <font color="orange">HO</font> Z-28
Old 03-17-2005, 05:36 PM
Default Re: Ceramic Coated Headers - Clean Up
Are they rusty or pitted?
Old 03-17-2005, 06:01 PM
A little pitted on the bottom of collectors, and slightly oil stained (on bottom of collector) from an oil leak.
Rob
Old 03-17-2005, 06:18 PM
Alan X77 Hugger Alan X77 Hugger is offline
Rob,
You can use Mothers Mag &amp; Chrome polish, but depending on how good you want them to look, you may have to have them re-coated. I had a set of Hooker Super Comp headers and after two years and not many miles they just looked like you are describing. The coating from Hooker is not the best, so I had them blasted down and re-coated inside and out. Not sure what level you want to take it.
Alan
Old 03-17-2005, 06:27 PM
Alan, I'm really want to get the oil stains off the bottom of the pipes/collectors. I know that the pitting can not be taken care of with out blasting/recoating.
By the way Alan, where do you live on the dark side?
Rob
Old 03-17-2005, 06:42 PM
Terrace Hill subdivision. It's on the South side of Algonquin Road across from Boulder Ridge. Try the Mothers, it comes in a small jar and it's available most anywhere. It should take the stains out unless they are really bad.
Where in Algonquin are you?
Alan
Old 03-17-2005, 06:55 PM
Carrington, which is behind the old Piggly Wiggly and near Presidential Park. Rt62/RT25
Rob
Old 03-17-2005, 11:30 PM
You can use OOOO steel wool also litely. I shoot a thin coat of vht aluminum paint. I just dust it on and it doesn't burn off. Too heavy, it will come off. I have been dodging this for 2 years. Next winter have to get them re-done. They only lasted 2 years from Hooker.
