Old 02-07-2005, 11:59 PM
DarrenX33's Avatar
Default Replace head bolts?
I am getting close to bolting it back together. Is is necessary to replace all the head bolts or can they be reused?
1969 Z28
1972 Corvette
Old 02-08-2005, 12:19 AM
Chevy454 Chevy454 is offline
Default Re: Replace head bolts?
Don't cheap out now, Darren, opt for the new head bolts, or you're likely to regret it...trust me, I learned the hard way recently...and DO NOT BUY MANLEY head bolts! ARP from now on...
Old 02-08-2005, 12:28 AM
Belair62 Belair62 is offline
What if he wants a bone stock factory correct replacement with correct markings ???
Old 02-08-2005, 09:34 AM
fpcopo fpcopo is offline
Come on BG you big sausage, don't you know nuthin? Paragon Corvette supply has accurate SB and BB head and main bolts. Great quality. I think Chevy still has them but they are not exactly like the old ones. Also if you feel you have to use washers, use thread sealer or they will leak sure as hell. Frank
Old 02-08-2005, 09:39 AM
Oh man whatever you do, don't use a regular tap to chase the threads in the block. You take out too much material and pull the threads out of the block! Heli coil time. Use a thread chasing tap or if you don't have that a nylon bristle brush and solvent usually works fine. Frank
Old 02-08-2005, 04:38 PM
bkhpah bkhpah is offline
Paragon sells accurate head bolts for BB's. Not sure about SB's. The Bb set sells for about 62.00...BKH
Old 02-08-2005, 06:11 PM
DarrenX33's Avatar
Thanks for all the advice guys. It's very much appreciated
1969 Z28
1972 Corvette
Old 02-08-2005, 12:46 AM
DarrenX33's Avatar
I am going to be asking a ton of questions cause I want this done correctly. I assisted with a complete engine rebuild years ago. So it's not that fresh in my mind.
Counting on the experience of everyone here cause the last thing I want to do is screw up my numbers matching motor.
1969 Z28
1972 Corvette
Old 02-08-2005, 12:59 AM
[/ QUOTE ]Always replace head bolts! You are not re-using your head gaskets are you??? You are a D@&amp;e! cheese steak man.
Old 02-08-2005, 01:08 AM
DarrenX33's Avatar
What a rough crowd.
I like this question. Any answers?
1969 Z28
1972 Corvette
