Old 12-19-2004, 11:46 PM
70 ls6 convert 70 ls6 convert is offline
Default trying to decode my 69 rs z28
I bought a 69 a year ago, and getting ready to restore it,has been sitting sence 1986,no motor or trans,yesterday i pulled the seats,and found some of those old beer tabs,and old change,it was kinda cool,im searching for a build sheet,its funny i never occured to me that rats could destroy them untell i pulled the rear seat,and found 100s of ,i think acorns?well anyway im having fun taking the car appart,and trying to document it,i took some pictures of it,but not sure how to attach them,any help would be awsome,thanks vin 124379n519306..i founf a date on the inside of the door pannel,8-13-68..i got a picture of the trim tag,il post when i figure it out. it says ,,,st6912437nor126297...next line tr711 57 57 pnt,,,next line 10 b...i fond numbers on the rear end#bu 100801 and the letter e is directly under the 100 numbers ,any help would be great thanks..
Old 12-20-2004, 12:46 AM
drdave69 drdave69 is offline
Default Re: trying to decode my 69 rs z28
First thing to note is that you will most likely NOT find a build sheet in a Norwood built Camaro.
As for some of the decoding - According to the cowl tag info, your interior (TR 711) is black standard, the exterior paint color (57 57) is Fathom Green top and bottom. Your body date is the 2nd week of October 1968 (thus no X code on the tag).
The rear axle numbers are for a 3:73 (BU) posi assembled on October 8.
Dave
1987 Grand National
Old 12-20-2004, 01:08 AM
Unreal Unreal is offline
Without paperwork, or original driveline, it's nearly impossible to prove it's a real Z/28. You will have to rely on detective work to "deduce" its origin. Do a search here, and Team Camaro (Camaros.net) to get a list of clues. BU rear is a start, as that was the standard rear on the Z. Of course, it was available on other models, too.
Old 12-20-2004, 01:25 AM
Pull the back of the back seat out and look on the X brace on passenger side and read the grease pencil code. Does it have the original radiator? (CB) code on the passenger side tank. How about your carb linkage is it correct? Should be 2 piece and have a bend in it. Single fuel line (3/8"). 7000rpm tach with a redline starting at 6000. Motor mounts on the frame should be #'s 507 and 508. Brake booster if original should be 9204. Metal bracket welded to drivers side rear frame rail (in the wheel well) for the dual exhaust hanger. Hope this gets you started. Sam
Old 12-20-2004, 03:58 AM
DarrenX33's Avatar
Nice tip on pulling the back seat Sam. Depending on if you have style trim or not. I would expect to see one of the following there. DG3, DG7, X3, X7. It's an early car. I'll bet it is there unless someone was monkeying around with paint back there.
Kris you can send the pictures to me I will get them posted for you. [email protected]
Have fun.
1969 Z28
1972 Corvette
Old 12-20-2004, 04:28 AM
Well Darren, You know how the early cars look behind the seat. We clarified each other on that!
Old 12-20-2004, 04:57 AM
DarrenX33's Avatar
Sam, yours was DG3 correct? Actually you should post the pic of your car so Kris knows what it will look like when it's done. You guys are a near exact match.
1969 Z28
1972 Corvette
Old 12-20-2004, 05:23 AM
Belair62 Belair62 is offline
Don't go there Darren...I've been trying to get him to send me some pics for a month now !!! He just ain't geeky enough....YET !
Old 12-20-2004, 05:38 AM
hey thanks for all the help,this is great. i tride sending darren the pictures,but they come back returned ,must be my slow dial up,i will keep trying ,hey thanks again and merry xmas...to all...
Old 12-21-2004, 06:56 PM
Racefan Racefan is offline
Darren-
Forgive my ignorance, but what do the other codes (besides the X3) represent? Is there a place where all these hints are written down? I have a Norwood 68 that was just a 327 car, but don't know what other options it had. Is there a way to tell? I know it had a console, the holes are there. What else can I find out by marks on the body and such?
Phil
'68 YENKO CLONE PROJECT
