Old 10-10-2004, 03:00 AM
indyjps indyjps is offline
Default 1970-1971 camaro parts needed list attached
friend sent me a list of items he's looking for maybe someone can help out. thanks indyjps
John Fort
Email: [email protected]
1970 ½ Camaro Z-28
Build Date 3rd week February 1970 Norwood Built Car
Standard Body Style – Standard Black Interior
Used or NOS parts needed:
? Dash Gauge Bezel - must be v.good to excellent condition
?? Gauge Cluster with Unbroken Mounting Tabs
Original NOS Embossed Bowtie Wheel Center Caps #3989479, gr.5.871
?? (4) 70 Date Coded 5-Spoke Rally Wheels - K10 1 or 2 AU 15X7JJ
70 Date Coded 5-Spoke Rally Wheel - K10 1 or 2 AU 15X7JJ (for spare)
? Original Date Coded Jack (9M – 0B) with Mast
Original Tire Tool Lug Wrench – Ύ inch
Original Plastic Jack Cover with Flap
LH Exhaust 3942527 2.026", Rear Outlet, AIR - dated late Dec.69- Jan.30, 70
RH Exhaust 3946826 1.96", Rear Outlet, AIR - dated late Dec.69- Jan.30, 70
??? Engine Hoisting Hooks for Intake Manifold - Small Block
?? Original Small Block Timing Cover with Welded on Timing Scale (8 in. balancer)
(late Dec.69 to late Jan.70 dates)
Original 270 BR coil
? Rear of Hood Stainless Trim– Style Trim Group
? Top of Fender Stainless Trim– Style Trim Group
? Stainless Roofrail Moldings – Style Trim Group
NOS Front Parking Lamp Lense with Stainless Trim – (LH) Std. Front End
?? Seat Belt Set – Dated Jan.-Mid Feb. 70 ( 1st – 6th week) 1 to 6 E 70
? # L 3973904 Top Radiator Support Piece – must be straight
? RH (passenger) Standard Wiper Arm (non hideaway)
Deluxe 4-Speed Console Plate with Burl Wood
? Deluxe Steering Wheel (or burl walnut horn center)– 70 only
? Rear Trunk Lid Torsion Springs (for Spoiler)
?? Original Twin Note Horns
Original Clips for TCS Temp. Sensor Wire
Original Voltage Regulator – # 1119515 Date – OA or OB
Original Smog Pump – dated early 70
1971 Camaro RS Z28
? Front Non-AC Kick Panels – Sandalwood Color
? Console or Parts (Lid)
Smog Equipment Tube – RH side
?? 5-Spoke Wheel (spare) - K10 AU 15X7JJ (dated before 9/15/70)
(1) Original NOS Embossed Bowtie Wheel Center Cap #3989479, gr.5.871
?? Original Date Coded Jack (0H – 0J) with Mast
??? Fan and Clutch Assembly – (have #3976064 – E70)
# 3953692 Small Block Waterpump – G-H70 dated prefer rebuilt
?? # 3957170 Waterpump – G-H70 dated prefer rebuilt
Original 270 BR coil ?
1114432 TCS Control Solenoid ?
? = Have but need better quality
?? = Have but need better date codes
69 camaro
Old 10-10-2004, 03:49 PM
Default Re: 1970-1971 camaro parts needed list attached
Suggest you post this list as a WTB: (wanted to buy) in the swap meet section at www.nastyz28.com. Some of the items like the TCS wire clip and Embossed BowTie center caps are next to near impossible to find.........
Chuck Sharin
Chuck Sharin
[email protected]
69 Camaro COPO "recreation"
Old 10-11-2004, 08:30 PM
BARN FIND BARN FIND is offline
Chuck Sharin
LOL...some are near impossible and some are just impossible.
There is a guy on EBAY sometimes that restores the shift plates. If I were you I would go to every swap meet I could. Some of those parts are only going to be found in someones basement or junk yards that don't crush the cars.
I am sure you know this but, this kind of stuff goes fast at swap meets. At Super Chevy Bristol I saw the wheels with the caps for $250, a excellent console with deluxe plate $150 and a F60-15 Wide Oval $25. This was at 7:45 am. By 8:30 they were all gone.
I wish you good luck and I hope you find everything you need.
72 SS 350 4spd Camaro
74 Z28 Automatic
80 Z28 4spd
94 Z28 Automatic
Old 10-10-2004, 04:22 PM
70 copo 70 copo is offline
Indy,
Looks like he is building a show car. That is indeed a tall order. It is right at the start of production, so it is early and many small engineering revisions on part numbers ocurred at that time. Wish him luck. The fastest and most cost effective way to find most of these parts may be to find a low mileage or original car with the right build date, buy the entire car it- strip the parts needed and then re sell the donor car.
