Old 08-08-2004, 05:00 PM
BARN FIND BARN FIND is offline
Default Restoring an intake
What is the best way to restore an aluminum intake so it retains the original finish and texture?
72 SS 350 4spd Camaro
74 Z28 Automatic
80 Z28 4spd
94 Z28 Automatic
Attachments - The Supercar Registry 92934-Shifter Mtg Brkt.jpg 92932-MuncieTailhousing.a.JPG 92931-MuncieSideCover.b.JPG 92930-MuncieSideCover.a.JPG
Old 08-08-2004, 07:18 PM
68z302 68z302 is offline
Default Re: Restoring an intake
This is probably one of the better ones.
http://www.z28camaro.com/restosvcs.html#AIM
I haven't seen one done but I've heard good things about it.
Does anyone know the "reskinning" process that's used by Jerry Macneish?
I do know that glass beading aluminum IMO doesn't look right
Rob
'68Z, original drive train
AS1 AO1 D55 J52 U17 U69 Z28
Old 08-08-2004, 07:22 PM
budnate's Avatar
budnate budnate is offline
I have been wondering the same thing, I have a Z intake that is all grimy, there must be something we can blast them with that will clean them up but not alter the finish....??????.
Bud.
Old 08-08-2004, 08:03 PM
If corrosion isn't a problem could you use a steam cleaner?
I don't mean a pressure washer either but an actual steam cleaner.
There must be some type of cleaner around you could drop the intake into. There was a thick liquid carb cleaner that came in metal buckets you could drop a carb into but I can't remember the name.
Seemed to do a good job cleaning aluminum carbs.
If you had some new stuff it could clean a manifold?
Rob
Old 08-08-2004, 10:51 PM
Untouched intakes are great. If you need to clean one real good, I use my friends safety clean tub and a good strong brush for cleaning. If you need it re-skinned call Camaro High Performance, (Jerry MacNeish)Does very good work. sam
Old 08-10-2004, 04:01 PM
Casey Marks Casey Marks is offline
* Soak / Scrub * cycle of the dishwasher.
Pressure wash first. Put in the dishwasher using the toughest setting. Make sure the Jet-Dry is full for no spotting ..... Once done, run it again empty.
All of this is of course, to be done, when the wife is out of the house for a few hours. It really does work good, I do it all the time with my aluminum W-31 Olds intake. Soon, the intake off of the Biscayne is gonna get "the treatment" ......
Disclaimer: I am by NO means responsible for any domestic disputes which result directly or indirectly from the use of the household dishwasher to clean parts.
Old 08-11-2004, 04:40 PM
juliosz's Avatar
juliosz juliosz is offline
I was told by a respected member of the Corvette and Camaro communities that Jerry M uses a "tumbling" process with a proprietary media. All I know is my intake looks beautiful since Jerry did it and at a reasonable cost ($120.00 two years ago). If you check out his web site he also has pics of some of the aluminum repair jobs he has performed, some truly amazing.
Old 08-11-2004, 11:28 AM
mssl72's Avatar
mssl72 mssl72 is offline
I had the intake on my Caprice put through the Vibratory process also. It came out looking NOS. I was very pleased. Now the only delema is whether or not to do the overspray when painting the engine. Jerry MacNeish restored my alternator and starter. He does great work. I've got a few carburetors for him to do in the near future.
Mark
1966 L72, 4spd Caprice
1974 Z28, M40 Camaro
