Old 07-14-2004, 12:48 AM
FrankieZ FrankieZ is offline
Default Decodeing the Chevelle
Hi Folks
How would i find out what the rear axel ratio that would have come from the factory on my new toy(70 chevelle SS) the window sticker just says Option G80 Positraction Axle.
Is there a good reference site for this ?
heres the option list :
771 saddle interior
2B Vinyl Top-Black
A01 Tinted glass
A51 Bucket Seats
C08 Vinyl Roof Cover
D55 Center Console
G80 Positraction Axel
M22 Special 4 spd Transmission
T60 Heavy Duty Battery
U35 Electric Clock
U63 AM Radio
V01 Heavy Duty Radiator
ZL2 Cowl Induction Hood
Z15 SS 454 Equipment
FrankieZ
98 vette conv Dyno at 410hp
01 BMW X5
03 Jaguar
1970 Chevelle LS5
Old 07-14-2004, 01:14 AM
Chevy454 Chevy454 is offline
Default Re: Decodeing the Chevelle
Being an M22 car I'm gonna guess 4.10s...
JoeG JoeG is offline
Well since you got your new toy I would go thru the whole car checking fluids---YOU should pull the rear cover off just to make sure no metal pieces are floating around--then count the teeth on the ring and pinion--Or jack up your car rotate the rear tire---ex.4:10 approimately ea. rotation of the tire would correspond to a 4.1 turn of the driveshaft etc.---If it was mine I would go thru the car---IMHO---
Old 07-14-2004, 01:18 AM
Already Checked that....currently it has 3:55 's so im trying to find out what actually came from the factory.
FrankieZ
01 BMW X5
03 Jaguar
1970 Chevelle LS5
Old 07-14-2004, 02:04 AM
YENKO DEUCE REGISTRY's Avatar
What is the dates on the ring gear? That might help to determine if the 3.55 is original or not.
Marlin
Old 07-14-2004, 02:13 AM
Your right there should be a date on the ring and pinion gear-----
Old 07-14-2004, 02:09 AM
Don_Lightfoot's Avatar
Was 3.55 the standard ratio on an SS454 manual transmission car? If so, then I would say the 3.55's would be correct for a car where no "performance" or "economy" ratio was stipulated on the new car order form. Posi was an option on virtually any ratio.
If I recall, I'm sure I have seen LS-6's, let alone LS-5's, advertised with M22's and 3.31 rear end. All in the hands of the person putting in the order.
Just my two pennies worth.
Specialized Chevrolet Decals
Alss's Avatar
Alss Alss is offline
My 70 SS LS-5 car...M-22..3.31 posi. Only two rear ratios for 70..3.31 Axle code CRV and 4.10.
ALbert
1969 Beaumont 540 th400 3.70
1968 Camaro ragtop LSA ZL1
Old 07-14-2004, 02:41 AM
COPO COPO is offline
In '70 I think most of the M-22 cars got the 3.31 unless the optional 4.10 was ordered. My LS-6 conv. had the M-22 & the CRV 3.31 rear.
Old 07-14-2004, 07:37 AM
If that axle housing is the original,relay the suffix code to us here,as well as the Rear cast date to verify.
It didn't come with 3:55,your VIN# comes up as a January date,and that is to late anyway.
The early built got a 3:55 standard or 4:10 optional.
Once the 3:31 started around the 3rd production month,the 3:55 was dropped from the line up.
It could have received either the 3:31 or 4:10 with an M22 Transmission,but because it was built with a V01 Radiator,I am leaning towards the 4:10 posi.
Seeing as this car was built at Oshawa,check with George Z. at Vintage Vehicle Services for the Factory Paperwork showing the rear RPO code.. should look something like GY2.
Georges Phone number 905-644-4060.
I'm confused...why are you claiming new ownership of this Chevelle,while it has been receiving new bids on Ebay during all this,and has only now just expired with a reserve price not met?
