Old 06-23-2004, 06:13 PM
Default 1970 camaro frame mounts
I have spent the last three days trying to locate my 427 in my camaro. Were the big blocks located off centre line same as the 68,69 camaro and nova's?? and are the trans mounts off set too? I used 2 1/4 Hooker header and they are way too tight against the frame rails. HELP KIM
Jake is my grandson!!
Old 06-23-2004, 07:05 PM
Pantera Pantera is offline
Default Re: 1970 camaro frame mounts
Are you sure that you have the correct brackets on the sub frame for a BB? They look a awful lot alike.
70 BM Phase III GT Vette
69 BM SS427 GT vette?
69 L78 Nova 7k mi
73 Pantera
69 Vette B/P SCCA
Old 06-23-2004, 07:48 PM
Kim, BB & Z-28 mounts are same #'s 3964886 and 3982307.....very rare pieces to find.......Chuck S
Chuck Sharin
[email protected]
69 Camaro COPO "recreation"
Old 06-23-2004, 08:35 PM
I used the small block LH 890 & RH 930 thinking this would center line the motor in the frame compared to bb frame mounts. They won't line up for the steel motor mounts not even close . I changed the mounts to lh 307 and rh 69 bb frame mount.With the frame mounts and the headers loose and the trans mount loose I tighted the frame mounts & headers than went to bolt the trans down and the trans had moved on the cross member a inch or more towards the pass side. Are the 70 bb not in the centered same as the nova's and camaro's. the header are 21/8 hookers and are VERY tight against the frame on both sides. Kim
Old 06-23-2004, 08:38 PM
Whats the frame mount # for a 69 bb RH side and is it the same as the 886 for the 70 camaro? Kim
Old 06-30-2004, 04:00 AM
MAX71Z-28 MAX71Z-28 is offline
First time posting on this board and I thought I might as well come in here with some great news
Big Block frame Mounts for 1970 Camaro
Found NEW Reproductions available from
Camaro Parts Network.
Retail for $149.95
Old 07-02-2004, 10:05 PM
Thanks Bryon. Kim I center lined the motor and used different frame mounts thanks again
