Old 04-21-2004, 03:21 AM
68ys8030 68ys8030 is offline
Default holley 3 barrels...
hey guys!
i've never run a holley 3 barrel before. I now have a stock 4346 on my 69 and was thinking of trying out a 4781 850. i've heard that the big 3 barrels never ran that good but have never tried one myself. i've seen 950's and 1050's
for sale on ebay. do you think one would out perform an 850 due to the size? maybe pete has tried one.
i am putting the motor back in my car after a few mods and have been thinking at nite about this... i need more MPH!!!
let me know what you think.
thanks! steve keech sarasota florida
63 split window fuelie
69 z28
financing my 2 sons cars.... 67 fastback mustang and 69 Camaro.
Old 04-21-2004, 04:15 AM
JoeG JoeG is offline
Default Re: holley 3 barrels...
On the 950,when you get the secondaries to open at the right time and ample fuel gets delivered to prevent a slight bog it pulls like a bear on top end---All these things can be accomplished with a little work----BUT it can be done much easier with 3310 OR 850 DOUBLE pumper---especially having secondary jets to play with.---JoeG
Old 04-22-2004, 02:27 PM
I have taken the 850 off my ZL-1 and put on a worked 850 that flows 996cfm. The car slowed down a little bit. since that test though, I put on a new fuel pump with my stock 850 and picked up 3 mph!!! So now i will have to try the 996 cfmer again. Keep in mind this is with a stock cam and exhaust manifolds. When i bought that carb, it was for my 55 Chev with a 502/headers and it picked up 3 tenths instantly.
Peter
Pete Simpson 1962-2013 RIP
Owen Simpson
Eric Simpson
Old 04-23-2004, 12:51 AM
Chevy454 Chevy454 is offline
I have taken the 850 off my ZL-1...
Must be nice!
Old 04-23-2004, 01:50 AM
COPOPETE,
When you said you replaced the fuel pump--was the pump wearing out or did you step up to a pump with more flow --JoeG
Old 04-23-2004, 01:56 AM
It was a brand new GM pump for an L-72. I put an Holley pump on it. Also I use the 3/8 line to "T" with 5/16 which likely does not help it any! Also found it interesting that going from a 780 vac to 850 DP the car picked up 3 tenths in back to back runs. When they tested Charlies ZL-1 in 69 they were running the 780 vac on it from what I understrand!
Peter
Peter
Owen Simpson
Eric Simpson
Old 04-23-2004, 02:57 AM
[quote Also found it interesting that going from a 780 vac to 850 DP the car picked up 3 tenths in back to back runs.
Peter
Peter
Just to make sure----You mean you ran 3 tenths quicker???---Joe
