Old 12-17-2003, 04:17 PM
bilede bilede is offline
Default Yenko deuce rear sway bar.
Can anyone provide me with the width from side to side of the rear swaybar for a deuce along with how long are the vertical bars? I picked up a complete setup and I think the bar is correct but not sure about the verticals.. [img]/ubbthreads/images/graemlins/dunno.gif[/img]
Old 12-17-2003, 04:55 PM
YENKO DEUCE REGISTRY's Avatar
Default Re: Yenko deuce rear sway bar.
I can measure mine tonight.
The 'hangers' should bolt below the bar, not in front of it, when properly mounted to the special lower leaf spring brackets.
Marlin
Old 12-18-2003, 05:42 PM
thanks Marlin, that would be great if you would.. [img]/ubbthreads/images/graemlins/worship.gif[/img]
Old 12-23-2003, 03:11 AM
Help, still no answer, does anyone have this info please???
Old 12-23-2003, 09:01 PM
mnyenko mnyenko is offline
Bill,
The sway bar set up you saw in my garage measures 38 1/4" wide on bar.The verticals measure 11 1/2" center to center on bushings.Over all 13" on verticals.This unit is from a 74 nova with f41.The verticals have the lower bolt connection facing the wrong way for a 70.But should be the same dimensions.Earl
Old 12-24-2003, 03:32 AM
Bill, I will try to remember to measure mine. You most likley will have to remind me though. Send me a pm if I forget. Schonye
Old 12-24-2003, 10:48 PM
JRSully JRSully is offline
Measured the rear sway bar off my 70 L78 F41 car, 38 3/8" tip to tip, with a yellow paint mark on one end, hope this helps.SULLY
71 Porsche 911 Targa
