Old 09-16-2003, 03:49 AM
DSYenko DSYenko is offline
Default 1970 L-78 short block for sale
I have a 3969854 short block dated E 28 70 stamped "CE" that I am considering selling.To the best of my knowledge it's standard bore and crank.I will verify this before I consider it sold.Cam and chain are gone.It looks pretty original as most of the paint is gone ect.I did notice some permatex on the rear main.Has domed pistons,stock I assume? Price is $2750. Im in Iowa, PM me with questions. Thanks
EX 81 YENKO TURBO Z owner
Old 09-16-2003, 11:30 PM
Default Re: 1970 L-78 short block for sale
Can you tell me the Digits stamped after the "CE" code?
Old 09-18-2003, 01:40 AM
I will check on Thursday and list the numbers.I did measure the bore and it was 4.125 would'nt that be .30 over? Update tomarrow stay tuned !
Old 09-18-2003, 02:35 AM
Musclecarkid Musclecarkid is offline
All 70 396 engines were .030 over from the factory. Actually 402 cubic in. but were still marketed as 396 engines.
Kevin
1970 Chevelle Droptop
Period Correct Speed Parts
482 BBC, M22 or TH400?
Day 2 Super Stock Rocks
Old 09-18-2003, 03:29 AM
I feel better now,,,,,,,, I thought this thing was standard!Im gonna pull the pan tomarrow if I get time and check the crank specs ! Thanks for the info,,your the man!!
Old 09-19-2003, 01:13 AM
I took the pan off and the crank number is 3904815NF dated K 16 8,it is 10/10. 2 bolt block. CE153074. Ok so whats the deal 2 bolt 854 block with a cast crank.Has the crank been replaced or did they use that block for more than the
L-78's? There was goop on the pan gasket so it has been apart.It does say pass-hi perf on the back. [img]/ubbthreads/images/graemlins/dunno.gif[/img]
