Old 09-13-2003, 02:13 AM
SYCIWISH SYCIWISH is offline
Default need pics of rear disc brake brackets
searched the web pretty good but can't find pics. I may have stumbled onto a set of JL8 brackets but they are also might be second gen firebird. thanx for any leads. DAVE
I started out with nothing and I still own it damnit!
Old 09-24-2003, 12:12 AM
Default Re: need pics of rear disc brake brackets
nothing?
Old 09-24-2003, 01:04 AM
budnate's Avatar
budnate budnate is offline
Look on e-bay, I think I saw a guy selling re-pop stuff a week or two back, he had lots of pics of his stuff for sale.
Bud.
Old 09-24-2003, 01:49 AM
Enoch Enoch is offline
Banned
factory installed JL8 rear disc brake caliper brackets are the same as 65-82 corvette rear caliper brackets (They used 2 of the same side, I forget which side, and flipped it around on the other side). So if you need to see a pic just look it up in an on line corvette parts catalouge.
Hope this helps.
Old 09-24-2003, 12:54 PM
COPOL89 COPOL89 is offline
Heres a rear Corvette right side caliper mount PIC. They used 2 left side brackets to clear the shocks. [img]/ubbthreads/images/graemlins/scholar.gif[/img] but the JL8 brackets will not fit the camaro or chevelle 12 bolt rear backing plate flanges that is what made them unique to the JL8 housings you have to use the backing plate flanges from the 67-72 1/2 ton C-10 and weld them over the 12 bolt flanges then shim the caliper brackets to fit the longer production 12 bolt axle because the JL8 axle is also different, then the emergency brake cable is another story.-Denny
69 L89 CAMARO RAGTOP
