Old 07-23-2003, 01:09 PM
JRSully JRSully is offline
Default Traction bars with F41 Rear Sway bar
Has anyone run traction bars and still been able to mount the factory rear F41 sway bar on Nova's and Camaros.?? As I see it, the factory lower mounting plates have the extra material/mounting area for the rear sway bar brackets (if you ordered the F41 suspension) and most traction bars that replace the lower bracket don't have this. Can you Sandwich the two plates together.??? Any ideas are appreciated
71 Porsche 911 Targa
Old 07-23-2003, 01:22 PM
YENKO DEUCE REGISTRY's Avatar
Default Re: Traction bars with F41 Rear Sway bar
Jim;
There are some Yenko Deuces that have traction bars along with the rear sway bar. They are unusual looking bars, I will try to dig up a pic. I have an excellent pic of one Deuce, he even painted everything white under there - makes it very easy to see!
Marlin
Old 07-23-2003, 01:42 PM
Thanks Marlin, could use some ideas, as I am day 2'ing. This car will be DRIVEN, and the last owner already ripped half of the welded sway bar mount off the trunk floor with some spirited driving back in the early 70's. Would like to get Motion type bars if possible, as that is what I am loosely basing the day 2 theme on. I have most of the stuff already, orig Motion valve covers, full set of Sun gauges/tach/decals. Thanks again for your help, look forward to some pics, how's the 69 coming.?? Sully
Old 07-23-2003, 02:48 PM
I'd be interesred in seeing those sway bar/traction bars pic too. I didn't think you could do both. I know that if you change the height of the rear of the car, as in air shocks/shock extensions the bar doesn't set, or work very well.It actually turn upside down. Schonye
Old 07-23-2003, 04:27 PM
I am thinking that you could probably use the cheesey bars that only bolt to the 2 front mounting holes instead of the normal bars that bolt to all 4 attaching points/replace the complete lower plate. We patiently await your pics Marlin.!!
Old 07-23-2003, 04:40 PM
Ok, I will work on the pic scanning some more! I know that BKH has some pics as well, they are from an original owner deuce. The bars are cheesy lookin, not very good quality - they actually look homemade, but the owner says they weren't. Now that I think of it, I believe another orig. owner deuce has traction bars and the sway bar intact, I will pull those pics as well.
Marlin
Old 07-24-2003, 05:02 AM
Sully, if you're looking for the motion traction bar look, I think most of those used the J bolt setup. Sway bars help cornering, traction bars are for straight line. My 2 cents is that a combination of the two would tend to work against each other, or help very little. Schonye
