Old 06-24-2003, 11:23 PM
Default Coil Sping Advice Wanted 69 Camaro Big Block
Does anybody reading this have ACCURATE knowledge as to what mfg (MOOG, TRW, etc) or vendors (RICK's) front coil springs will be "CORRECT" on my 69 Camaro Big Block without A/C and which companies springs I should avoid....I have already bought the multi-leaf(5) rear springs from HeartBeat City.....If you'd please copy and paste your response to [email protected] I would appreciate your experience.....Thanks, Chuck Sharin
Chuck Sharin
[email protected]
69 Camaro COPO "recreation"
Old 06-25-2003, 02:17 AM
x44d80 x44d80 is offline
Default Re: Coil Sping Advice Wanted 69 Camaro Big Block
The springs I have bought from the vendors are usually a little thicker diameter and missing 1 coil but the rate is the same so they are not "concourse" correct but if your not sharp you cannot tell by looking under the car. I keep the originals,blast them and reuse them. If I was going to race, or enjoy not show the car go with Moog, do a search at Camaros.net in the Suspension section.
