Old 04-24-2003, 04:04 AM
Stefano Stefano is offline
Default 450 hp L72 rating
The 427 L72 was released in the 1966 Model Corvette and rated by the factory at 450hp in the early car and 425hp in the later cars. Same engine different rating. The L78 /396 was also rated at 425hp for the '65 Corvette.
While I certainly can't speak for the man, I would speculate that Don Yenko who was very familiar with the Corvette Engine used GM's own marketing specs. and Dyno Results to rate his Super Cars.
It was after all the same L72 over the counter blocks which Yenko Sports Cars Inc. began installing between the fenderwells of their first Camaro Super Cars.
Just My opinion and observations.
Attachments - The Supercar Registry 41305-COPO 427 Engine.JPG 41302-Ken's COPO Engine 1.JPG
Old 05-21-2003, 06:36 PM
jg396 jg396 is offline
Default Re: 450 hp L72 rating
Speaking of the 425hp 396. Would you happen to know of where I could get the spec's on this engine? I'm looking to build something similar for my 1969 SS/RS 396 Camaro. I've got most of the parts to build this motor except for the spec's for what cam was used and any other special parts. Your help would be greatly appreciated. Thanks, Jesse [img]/ubbthreads/images/graemlins/biggthumpup.gif[/img]
Jesse
1969 Camaro SS/RS 396
Old 05-21-2003, 06:55 PM
Chevy454 Chevy454 is offline
I believe it's just standard issue L-78 (396/375hp) stuff. What kind of specs you needing?
Old 05-21-2003, 08:04 PM
From dyno specs etc that I have seen over the years, I would think that the 396 at 375 hp, the 427 at 425 and the 454 at 450, are probably right in the ball park for stock engines. I think Peter Simpson's motor was somewhere around 430 hp and an LS 6 was somewere around 460. We have had a couple of stock L78 Chevelles, with headers, over the years and they are definitely down on horsepower and torque compared to the L72 motor. Until 1966, most companies were putting some pretty bogus numbers on the breathers. Once everyone started racing, reality set in. [img]/ubbthreads/images/graemlins/smile.gif[/img]
Old 05-21-2003, 10:07 PM
Belair62 Belair62 is offline
OK so what was on each Yenko Camaro air cleaner lid in 1969 ? 425 horse,450 horse or nothing ????
Old 05-22-2003, 06:27 AM
The Yenko Chevelle tested in SSDI in '69 didn't appear to have any breather decals.
Old 05-21-2003, 10:53 PM
Our last L-72, built EXACLTY as the factory did it (10.2:1 compression ratio) in 1969, made 425hp on the dyno through the stock exhaust manifolds and head pipes.
Old 05-22-2003, 12:56 PM
I was just looking to find out the information I would need to find the correct cam to build 425hp out of my stock 375hp 396 motor. I was thinking if I went with what ever spec's where used on this vette motor. I could possible get the same 425hp. Or something close to that. I'm looking to go totally stock with it on the outside(valve covers, smog, carb, intake etc..). Then as close to stock as possible on the inside. I have the stock dimple rods and correct crank for it. When I have the machine shop get pistons for this motor what kind of compression should I be trying to get to. I've heard that stock was 11:1, but then I noticed that it's been mentioned to be actually 10.2:1 too. Which would be best to go with. I plan on driving this car a far amount (1000 miles or less a year). Also is thier a brand of piston that would be the best to go with that you guys like to use. I want to do this thing once and be done with it. I don't know if this matters or not but I will be putting 842 aluminum heads on it. Any help would be greatly appreciated. Thanks guys. Jesse [img]/ubbthreads/images/graemlins/burnout.gif[/img]
Jesse
Old 05-22-2003, 06:24 PM
There was an article (I believe he actually wrote it) about Bill Thomas in Hot Rod Magazine Circa Mid to Late 1966 on Blue Printing the L72.
I don't have the actual magazine available. That article was part of the Manual which Bill Thomas wrote on Blue prining the L72.
I seem to recall that the Dyno Hp was well in excess of 450hp when the engine was brought up to mfg. specs.
Does anyone remember the article?
Click to visit the Nickey Performance Facebook--&gt;
