Old 02-28-2003, 06:16 PM
budnate's Avatar
budnate budnate is offline
Default Pump to carb L-T1, fuel lines, repo ok???
Howdy, a question for the Deuce guys, I need a pump to Holley fuel line set and have purchased some repo stuff lately and to be honest have been very disappointed with the stuff these people are passing off as GM repo parts, Where are you guys getting your lines? They donít need to be concourse perfect just bolt up and not leak; I am not going for a pointís car just a respectable driver,
Thnx for any info, Bud.
Old 02-28-2003, 06:18 PM
Default Re: Pump to carb L-T1, fuel lines, repo ok???
Why not get a tubing bender and bend one up out of straight stock, available at NAPA.
-Sam
Old 02-28-2003, 06:28 PM
RonNova396L34 RonNova396L34 is offline
Bud,
I got my Nova's fuel lines from NNN. I thought they worked great and fit too. Mine was BB though. Here's their web site.
www.nnnova.com
Ron [img]/ubbthreads/images/graemlins/biggthumpup.gif[/img]
Old 02-28-2003, 08:06 PM
68l30's Avatar
68l30 68l30 is offline
I have purchased from both Fine Lines and The Right Stuff.Never had any problems with either......Fine Lines even custom bent for a modified application.I have used steel for fuel lines,looks right,seals right. [img]/ubbthreads/images/graemlins/biggthumpup.gif[/img]
Steve
Old 02-28-2003, 09:37 PM
YENKO DEUCE REGISTRY's Avatar
I have used The Right Stuff for my Deuce, I have not had any problems with fit or leaks. The short lines from the brass 'Y' block to the carb inlets are a little tight, but nothing to write home about. I have heard good things about Inline Tube as well.
Marlin
Old 02-28-2003, 10:13 PM
JoeC JoeC is offline
I hear some people have trouble with stainless steel lines leaking. The theory is that the SS is harder and does not seal as well as the softer steel line in the compression fittings. Other people say no problems with SS line leaking.
Old 03-01-2003, 12:58 AM
Belair62 Belair62 is offline
Stainless is a pain....very tough to seal....even with correct tools its very tough.
Old 03-01-2003, 01:44 AM
budnate's Avatar
Thnx Guys, Sounds like steel is the way to go. I will hit those two sites any idea what they ask for a complete set with Block?
Thnx Bud. [img]/ubbthreads/images/graemlins/[/img]
