Old 12-06-2002, 05:23 PM
RonNova396L34 RonNova396L34 is offline
Default Big Block Front Coil Spring Decals
When I tore apart the front end of my 1970 Nova 396/350 hp, I found the coil spring decals were still there and were still readable. The code was: HH and the number with it was 3955727. I had new decals custom made for my car. I made 2 extra sets in case I messed some up. I now have them just sitting around and I will post them under the parts for sale but I first wanted to find out what they might fit. Since my car is an early 1970 production car, August 1969, they might also be correct for a 1969 big block Nova. I have no way of checking on this number. I suppose somebody that can decode a build sheet might have the answer as to what it all may fit? I'm guessing it is a very specific number for a big block 1970 Nova and that is it. I will be more than willing to get these to somebody that really needs them. They aren't being reproduced. What I have is it unless somebody else took the time to do the same thing. Ron [img]/ubbthreads/images/icons/smile.gif[/img]
Old 12-06-2002, 05:52 PM
Default Re: Big Block Front Coil Spring Decals
RonNova396L34;
3955727 HH will fit a 70 Nova. It was a big PR thing for GM when they stated that they used an EDP (Electronic Data Processing) process to specially select the right spring for your car based on options ordered. Basically they calculated the overall weight distribution (front and rear) for the car with all of the options on it. The total front and rear weight determined the spring code that was printed on the chassis broadcast sheet. There were 27 different front springs for the 70 Nova alone. Quite a few overlapped with the 69 Camaro (as you know).
The parts books give some charts to help figure out what spring to use, but they usually only list 3 or 4 service springs. Other than COPO cars which were at the extreme end of the spectrum and had fairly limited options installed, it is harder to determine what spring was on your car once the tag was gone. A 307 with custom interior and AC might use the same spring as a stripped big block car. It all depended on the total options on a car.
Does this help? Sorry for the long reply, I have tons of time to kill before I head to O'Hare and fly home
Greg
Old 12-06-2002, 06:54 PM
Greg,
Very interesting. My car was basically a stripped down version. Steel wheels. Small poverty hubcaps. Non-console floor shift. No power steering, no air, no smog, no side moldings, no rear sway bar . It has bucket seats, carpet, power disc brakes, AM radio, front sway bar.
Ron
Old 12-08-2002, 10:35 AM
These decals are now for sale under the parts for sale listing.
Ron
Old 12-12-2002, 06:36 PM
JRSully JRSully is offline
Ron, new to the site, very informative. I have been following your articles in NNN, your car is coming along nice. I am currently doing a frame off resto on a 70 L78 Nova 4spd, Deluxe Bench interior,orig Eng, orig rear, correct tranny. Fathom Blue, Vinyl Top.My car was lucky enough to have been off the road since 76, tore my subframe down and found the same blue HH spring tags and orig. spiral shocks still there. i was going to have them copied as you did, but may just buy them from you if still have them, let me know Thanks
JR Sully
71 Porsche 911 Targa
Old 12-12-2002, 07:00 PM
Get his video too, pretty informative so far even though I am only a short way through it.
Old 12-18-2002, 08:20 PM
JR,
Just noticed that you said you found your original spiral shocks! Can you tell me what the part numbers are and if the original tags were still there? Thanks, Greg
