Old 11-08-2002, 02:41 PM
Guest
Posts: n/a
Default Motor identification
Can someone tell me what this block is. Passenger side rear block:184L, driver side rear block:GMT14, and W (or 11)0124454, On rear block has hi-perf and below that pass. Has to120tkb on front center of block. Vin on pad under pass head is ccs131919. Thanks
Old 11-08-2002, 02:53 PM
YENKO DEUCE REGISTRY's Avatar
Default Re: Motor identification
The code on the front/center of the block, is it stamped onto the cylinder pad? If so, the TKB indicates a Truck block, probably a tall decker.
Marlin
Old 11-08-2002, 03:02 PM
Guest
Posts: n/a
Marlin, no it is not. They are seperately stamped. One on the cylinder pad, the other on a pad that is centered on the top front center of the block, just under the intake manifold.
Old 11-09-2002, 12:43 AM
Marine block?
Old 11-09-2002, 03:01 AM
Rat_Pack Rat_Pack is offline
Dave, here is the info we spoke about earlier. Cast number shows 1975-87 454 truck (not tall deck), engine cast date of Dec 18 1984, engine assembley date of Jan 20 (1985), engine code equates to a 1985 454 240hp. Hope this helps. Great talking to you! [img]/ubbthreads/images/icons/grin.gif[/img] .........RatPack...................
Hey didn't I just increase Tim's credibility? Now he owes me again! [img]/ubbthreads/images/icons/shocked.gif[/img]
Old 11-09-2002, 03:10 AM
copolocater copolocater is offline
I'll send Dave a bill we'll split it [img]/ubbthreads/images/icons/tongue.gif[/img]
Old 11-09-2002, 12:33 PM
Guest
Posts: n/a
Troy, thanks for the info! Tim, thanks for the lead! Give me your fax number so I can fax you a check. [img]/ubbthreads/images/icons/smile.gif[/img] This motor was in a chevelle that my father had just bought as a driver and did know what it was out of. Thanks again!!
