Old 08-29-2002, 09:42 PM
Jeremy Jeremy is offline
Default ZL1 head gasket question?
What gasket was use from the factory? The car had copper gaskets when torn down. Would a good Fell pro composition gasket with a steel compression ring be fine for the aluminum block and heads? I am assuming the torque specs are the same as an iron combo? It never hurts to double check. Thanks guys.
Old 08-30-2002, 12:28 AM
allcamaro's Avatar
allcamaro allcamaro is offline
Default Re: ZL1 head gasket question?
Be careful because the last two L89 cars I did had a very different gasket that iron head.I have a L89 engine at the shop now and ill check with my tech and see what he says is right.
1967 Nova SS L30
1967 Chevelle L79
1969 RS Z/28 Red
1969 RS Z/28 Lemans Blue
1970 Z/28 Blue
1967 RS Convertible
1968 Camaro SS
1992 GMC Yukon 30166 miles
Old 08-30-2002, 02:40 AM
bbdon bbdon is offline
Here is something that I posted a while back. I think that while the torque specs are the same, they did use longer bolts.
Old 08-30-2002, 02:29 PM
Thanks for the help guys, The car will be on hold until we find out for sure.
Old 09-21-2002, 09:30 PM
Thanks for the help guys we went with the Fell Pro.
