Old 08-14-2002, 11:07 PM
copolocater copolocater is offline
Default Copo Scuncio
Anybody that might not know Ray Dupont's copo is for sale.Black/black just won Super Chevy Top 10 drag car award.Doesn't have original drive train but does have 512 4 bolt block.Paint is exceptional and car has been doc'd by Ed.Price is in the $50's or without drivetrain in the $30's.Don't hold me to it.You can call Ray at 919-304-6903.
Old 08-15-2002, 03:43 AM
Chevy454 Chevy454 is offline
Default Re: Copo Scuncio
Top 10 drag car? What kind of ETs does this thing do? What drivetrain, mods, etc.?
Old 08-15-2002, 05:09 AM
Rob Super Chevy gives away a trophy for ten different catagories,such as best paint ,engine,original ,drag car etc.The car now has an aluminum head 427.I think the car runs 10's. It has some upgraded electrical components which can easily be removed.NO body mods that I can remember.Won't take much to give it that out of the seventies drag carlook.Hope it helps. It's a good buy for the price. Better buy if you have a drive train.
Old 08-15-2002, 05:44 AM
Stefano Stefano is offline
There was a prior thread on the car with some pictures here on the site.
Old 08-15-2002, 12:28 PM
Jeff H Jeff H is offline
Does is still have the original BE 4.10 rear?
Old 08-15-2002, 03:08 PM
Rat_Pack Rat_Pack is offline
Here are the specs on the car: <ul type="square">
11k original miles
interior is original except for carpet and roll bar.
all sheet metal is original no rust
Engine: .030 over 427 2-bolt main, 12.5 - 1 comp 3/8" Dot Rods, block is studded, GM alum heads.
Transmission: Jerico 4spd with Mr. Gasket Vertigate shifter with line lock.
Rear end: GM 12-bolt with Moroso Brute Strength posi unit, 5.13 gears, c-clip eliminator, Summer Bros. axles, ET street tires.
[/list] The car still has the original curved neck radiator. The front brakes have been changed to drum, but he still has the original disc brakes. The dash still sports the original radio block off plate as no radio was ordered. I have attached a picture of the car taken last fall.................RatPack......................
* the other engine block he has is a correct 512 block dated D219 and the pad is stamped T023MN. He did not say whether there is a vin stamped into the block anywhere.
