Old 07-26-2002, 08:36 PM
whitetop whitetop is offline
Default Can my V-8 Dakota pull open car trailer?
Hello
Can my 2001 V-8 Dodge Dakota(4wd, automatic, towing package(extra coolers/heavier springs etc), 7000# towing capacity) pull an open aluminum car trailer, 1500# with a 64 1/2 Mustang Convertible weighing approx. 3200-3300#? Know the weight is less but have never seen anyone puling a trailer with a Dakota. Concerned about control and stability as well. Don't want to kill the truck.
Thanks
Dave
Old 07-26-2002, 09:38 PM
YENKO DEUCE REGISTRY's Avatar
Default Re: Can my V-8 Dakota pull open car trailer?
My Dad's '90 F150 with a straight 6 (300 cid), 5speed, 4x4, and a towing package pulls my steel trailer (1,600 lbs) with my Yenko on it (3,100 lbs) like it's not even back there - until a mountain, then it slows down considerably. The truck is rated at 5,700 lbs towing, but with the 5speed manual it drops to 5,200 lbs. If you keep it at 65mph, the momentum really pushes you along, less than 65 and your 'towing'.
As for stability, I have found the perfect 'balance' location on the trailer for the car. On the way to the York show, I rushed the loading procedure and had the car about 4inches behind my magic mark. No big deal until I was going around a bend at 65mph, the unbalanced condition was exaggerated, and the 'tail was really wagging the dog'. I thought I was going into the weeds, even though the truck is a std wheelbase. Next time, I will load the car to my exact mark.
With the Dakota, it should pull it fine, but just be careful to make sure the car is properly positioned in order to maintain balance. (Phil in MI towed his Yenko Nova home with an S10 Blazer pulling a 24ft. open trailer - no problems!)
Good luck, (Just don't run Firestone rubber, we've lost 3 treads - none while towing thankfully!)
M
Marlin
Old 07-26-2002, 10:41 PM
Thanks Marlin for the info. Also I checked on that Camaro in the local salvage yard that was reported to be a 427 on an old thread. Talked with the owner the other day. It is still there but it in only a original 396 car. I saw it, not much left. All the good parts have been stripped off or damaged in some way. Original rally green car. Subframe is there but no drivetrain or front end. A guy started to restore it back in the late '70's. left it outside for many years and Larry got it 15 or so years ago.
Dave
Old 07-27-2002, 12:33 AM
68l30's Avatar
68l30 68l30 is offline
Dave,we've pulled my open trailer with a 4X4 4.3 S-10 before.No problems,just be sure most of the weight is on the truck not the ass end of the trailer.
Steve
Old 07-27-2002, 02:00 AM
Pulling may not be as hard as stopping.Doesn't take much to push a lighter truck.I think you'll want real good trailer brakes. Ken
Old 07-27-2002, 02:05 AM
Very good point!!! My car on the sled can push the F150 around, that's when I know I didn't reset the brake controller from when I pulled the sled empty.
Marlin
