Old 03-16-2002, 07:13 PM
Unreal Unreal is offline
Default Negative Cable Routing
I've seen several nicely restored B/B with the neg cable attached to the alternator bracket. The assembly manual shows it being attached to the block. Which is correct?
Old 03-16-2002, 09:08 PM
micky69396 micky69396 is offline
Default Re: Negative Cable Routing
I think the block is more correct. I have seen this (alt bracket mounting) also on some pretty nice cars so there must be some form of documentation for it. Cosmeticely the block mounting looks a lot nicer.
Micky Hale
Hale Performance Consultants
Engine Parts Sales & Service
Old 03-17-2002, 01:10 AM
bkhpah bkhpah is offline
Late 1968 it was moved to the head..BKH
Old 03-17-2002, 05:54 AM
CDAUSA CDAUSA is offline
69 and 70 L78 Novas and the L78 Camaro had the negative cable bolted to the alternator bracket, with a 5/16 flangehead bolt and a full face starlock washer. The bracket is tapped.
Old 03-17-2002, 03:31 PM
Among the Chevelle Clubs and restorers,it has been documented as being done both ways.Plant and time period did not seem to be a factor,so it is considered correct either way,on 1970 Chevelles anyway.
I have pictures of engine compartments from 1970 showing two Kansas built Chevelles with ground in both locations.
I have seen cars grounded at the Head,but carrying Alt.bracket with a threaded hole unused.
This will always been argued between Owner & Judges.
Old 03-18-2002, 12:33 AM
Rat_Pack Rat_Pack is offline
The last two 69's I restored the negative cable was bolted to the head, 02B & 06A build dates. The assembly manual shows them to be bolted there also and the last update of the drawing for that was 05-26-69 when the cables went to side terminals............RatPack..................
