Old 01-29-2002, 12:36 AM
IRONCLAD IRONCLAD is offline
Default BALDWIN-MOTION
MOTION CARS HAD DUAL HOLLEY ELECTRIC FUEL PUMPS IN THE TRUNK; HOW DID THEY CUT OFF THE STOCK FUEL PUMP ON THE BLOCK?
ANYONE KNOW WHERE THOSE 3 TIER SPOILERS CAME FROM (CUSTOM MADE FOR MOTION? BY WHO?)
HOW DID THEY MATE THOSE 427SS EMBLEMS TO THE VALVE COVERS? I WOULD THINK THE HEAT WOULD DISSOLVE ANY GLUE?
THANKS AGAIN
Old 01-29-2002, 01:54 AM
BM71vega BM71vega is offline
Default Re: BALDWIN-MOTION
Ok for the stock fuel pump pull out the gas pump shaft and the put a block-off plate,and the ss427 that was screw in by in side,the spoiles i dont no sorry,i hope this help you.
Old 01-29-2002, 03:11 AM
PxTx's Avatar
PxTx PxTx is offline
The pumps I have seen were made by Autopulse. Motion would re-badge them as Phase III.
These Autopulse pumps were identical to the Dupree ones of the same vintage- at least mechanically. I think that each may have had the manufacturer's name cast in the aluminum housing.
They are a bellows type pump- or is that describing the regulator? They were often called tandem or duplex pumps. The parent company of both Dupree and Autopulse is Walbro.
If you are going for the look, JC Whitney sells a bellows type pump that is 12 V and has a similar feel, but will not support high HP.
I believe I have some old literature on a Motion installation of these pumps. I'll try and dig 'em out in the next day or so.
Paul
Paul III
Old 01-29-2002, 03:16 PM
whitetop whitetop is offline
I have actually seen in old pics that Motion used Holley, Stewart-Warner, Dupree etc fuel pumps. Probably a combination of what was handy, priced right, trick of the week or customer preferance.
I think alot of this had to do when the parts were issued. Motion used Mallory distributors etc almost exclusively until early '70's because that was the only company for the most part ofering these products out there. Accel came out with their ignition parts in late '68 early'69 and good competition 30100T model distributor in early '70. I've seen some of the later Motion cars with Accel components. Not sure though if they later were added by other owners. John Scanilli's red/white Camaro has an early Accel Distributor for instance.
Dave
Old 01-30-2002, 11:40 PM
GENTLEMEN:
THANKS FOR ALL YOUR INPUT. I FINALLY FOUND OUT WHAT TYPE OF EMBLEM THAT WAS ON THE VALVE COVERS; NOW I REALIZE THAT THEY HAD CLIPS ON THE BACK.
I HEARD THEY HAD A BLOCK-OFF PLATE WHERE THE STOCK FUEL PUMP GOES BUT I DON'T KNOW WHERE THEY GOT IT. ARE ALL OF YOU FROM LONG ISLAND? YOU KNOW THESE DETAILS PRETTY WELL. I COME FROM SMITHTOWN BUT UNFORTUNATELY, I WAS IN THE MARINES DURING MOTION'S REIGN.
G
Old 01-31-2002, 12:58 AM
Nope not from Long Island, from eastern Ohio. Not an expert by far just observations learned from mags back then with old Motion pics. Check out Cars Hi-Performance, Hot Cars, Rodder & Super Stock, Chevy Action and Chevy Power magazines from '68-'73. Motion stuff was in every issue just about.
Mr. Gasket made several types of chrome block off plates that were blister packed. Many other companies did the same thing-Cal Custom, Trans Dapt etc. Almost anthing would be correct for the era that you can buy today except the billet, anodized, hi tech versions that have been popular the last 10 years. This is one part that has not changed much over the last 30 years. I doubt if there was any "correct" part back then in this case.
Dave
