Old 01-14-2002, 01:19 PM
Bradley MacKenzie Bradley MacKenzie is offline
Default LT-1 Camshaft
If anyone out there knows the camshaft specs for an 1970 LT-1 would they be so kind as to post them? Please and Thank you in advance.
Old 01-14-2002, 02:29 PM
Rowdy Rat Rowdy Rat is offline
Default Re: LT-1 Camshaft
Bradley,
General Motors submitted the following specifications to the AMA in 1970 and these figures appeared in the February/March 1970 issue of Corvette News as well:
#3972178 (LT-1)
VALVE LIFT
Intake - .4586" (includes lash - .024")
Exhaust - .4850" (includes lash - .030")
(rocker arm ratio of 1.5 to 1)
VALVE TIMING
Intake
Opens (BTC) 4240'
Closes (ABC) 9420'
Duration 317
Exhaust
Opens (BBC) 11250'
Closes (ATC) 5323'
Duration 34613'
Regards,
Stan Falenski
Old 01-14-2002, 03:52 PM
On the subject of 1970 LT-1 camshafts......I just received one in a parts package deal that alledgedly is "Brand New". The lobes appear unworn and the bearing surface have a preservative on them......I can see a "GM" mark in the steel and some "pink" paint but othyer than having someone check the previously quoted specs how can I tell what it is?????.........Thanks, Chuck
Chuck Sharin
[email protected]
69 Camaro COPO "recreation"
Old 01-21-2002, 11:33 PM
YENKO DEUCE REGISTRY's Avatar
Chuck;
There should be a number stamped/cast on it somewhere, I think it should be 2178?
M
[Edited by YENKO DEUCE REGISTRY (01-21-2002 at 05:33 PM).]
Marlin
Old 01-20-2002, 04:12 PM
I have the original cam out of Dave Belk's
deuce, it's number is 2182, not sure if
replacement cams will be the same.
Schonye
Old 01-21-2002, 10:45 PM
Finally got around to examining the "LT-1" cam I spoke of above.......indeed the end is stamped with the 3972178 that Stan points out. On the rough cast area just forward of the dist drive gear there is "1539" cast in not stamped and 180' around same area is I 5,...possibly 1 5......are any of these #'s the casting dates, as I dont have the same 4 digit #'s the others above quoted......at any rate does NEW G.M. LT-1 cam have much value in anybodys opinion.....Chuck
Chuck Sharin
[email protected]
