Old 03-30-2002, 12:08 AM
Mr Yenko Mr Yenko is offline
Default Correct motor mounts?
I have what i believe are the orig. motor mounts to my COPO. Does anyone know the part number to these mounts? Thanks in advance,
Mayor of Fishkill
"POTTER BROS. SUPERCARS"
72 Nova SS "My first car of 30yrs"
70 LS-6 Chevelle Double Blk 30k survivor
Old 03-30-2002, 01:41 AM
JBB JBB is offline
Default Re: Correct motor mounts?
I have a L-78,69 SS, and I purchased a set
of N.O.S. pieces for our car a while back.
On the Part sticker on each Moter/frame mount are the #'s 3980941 and 3980942, respectively. I think the last four digits
of the number are stamped into the frame mounts also, on the lip that the bolts go through to the frame. Now I am not sure as to the fact that these are service replacements, or the actual assembly line parts. Joel
Old 03-30-2002, 01:46 AM
JBB JBB is offline
On the Part sticker on each Motor/frame mount are the #'s 3980941 and 3980942, respectively. I think the last four digits
of the number are stamped into the frame mounts also, on the lip that the bolts go through to the frame, facing upwards. I haven't looked at the parts in a while, and they are buried in the garage. Now I am not sure as to the fact that these are service replacements, or the actual assembly line parts. Joel
Old 03-30-2002, 01:47 AM
JBB JBB is offline
Old 03-30-2002, 02:08 AM
shor shor is offline
I believe the motor mounts in my car are original. Is the part # visible installed?
Old 03-30-2002, 03:53 AM
JBB JBB is offline
I haven't been in the garage yet. But I think I am correct in the assumption that the COPO L-72 and RPO L-78 incorporate the same frame mounts. I will look this Monday as I am off and will start spring maintenance
on the L-78 and I will check for you.....Joel
