Old 12-25-2025, 05:06 PM
Default Free Stuff
Just pay actual shipping. I use PirateShip.
All are new except the Air Cleaner, the antennae and the trim pieces.
I think I have posted a couple of these items before. Giving it one last shot before I list for free on FB. If I get no takers, then it is to the dump.
Aftermarket mismatched air cleaner. Base is chrome. Lid is aluminum. The base takes a 13.5 inch O.D. filter. The lid will cover that size just fine.... if you can find one. The lid would accept a 13.75 inch O.D. filter. Base has provisions for a breather hose. Be glad to separate if you can only use one.
Stewart Warner mechanical oil pressure gauge with light, and mounting hardware. )-100 psi. Standard size. No mounting bracket and no oil line.
GM coolant recovery tank lid. I don’t know what years this fits. I remember these on 70s and 80s cars. Still in GM box. Part number 14911345. Here is one for comparison. https://www.ebay.com/itm/18770458045...tion=view_item
Pair of Binks suction style spray guns. I have used both of these, and they worked fine last time I used them. One Binks Model 7, which was the standard for many years. The other is a Binks 2001 model. Both made in USA.
One Dorman power window switch, 901-017. Fits MANY GM vehicles from 1980 to 1987. Controls two windows.
One Auto Tune (never heard of that brand) vacuum modulator valve. I believe this fits early Ford (am I allowed) C4 and or C6 transmissions, as it is a screw in, not a push in style. Includes the gasket.
Sandwich style oil cooler adapter. I bought this for my El Camino, then realized it fit LS applications, and would not work on first gen SBC. Already has AN fittings for hoses. No hoses included.
Wix cartridge type oil filter part number 51954. Fits medium duty (C50, C60) Chevy and GMC trucks from the early 80s. Only used a few years, I believe.
One pair of style trim chrome strips to convert one standard 69 Camaro tail light lens to the “style trim” type. This is the only difference in the two lenses. Can be glued on.
68 or 69 (I believe) oval antennae. Not perfect by any means. Just have the mast. I have not done ANYTHING to it. Was in a box of parts I got. I will never use it.
Complete, still in the pouch, never used wrench set for Chevy and GM trucks and Suburbans, from 2000 to 2006 (I believe). Includes everything to remove lug nuts, remove the spare tire and operate the factory jack.
Will post pics of other items below.
The Following 2 Users Say Thank You to Lynn For This Useful Post:
396 SS/RS (12-27-2025), PeteLeathersac (12-27-2025)
Attachments - The Supercar Registry IMG_5220.jpeg DSCN9114.jpg DSCN9113.jpg DSCN9112.jpg
Old 12-25-2025, 05:08 PM
Spray Guns
Old 12-25-2025, 05:09 PM
Coolant recovery cap.
Window switch
Old 12-25-2025, 05:11 PM
Window Switch
Old 12-25-2025, 05:13 PM
Modulator
Old 12-25-2025, 05:14 PM
Oil Cooler Adapter
Old 12-25-2025, 05:16 PM
Oil Pressure Gauge
Old 12-25-2025, 05:17 PM
Antennae
Old 12-25-2025, 05:18 PM
Trim bars
