Old 10-15-2025, 04:22 PM
Wakepowell Wakepowell is offline
Default R59 Restoration Battery Rebuild
Has anyone here "re-powered" a R59 restoration battery. I successfully did this with my Chevelle's R79 side post battery. It was easier because the R79 top was simply epoxied to the restoration battery body. It is difficult to tell where the R59 battery is separated to install the gel battery.
Attachments - The Supercar Registry Battery rebuild 2529 4.jpg Battery rebuild 2529 3.jpg Battery rebuild 2529 2.jpg Battery rebuild 2529 1.jpg
Old 10-15-2025, 04:37 PM
1967 4K's Avatar
1967 4K 1967 4K is offline
I’m interested in doing the same job. Looks to me as if we’re going to have to cut the top off.
Am I wrong?
Richard
1967 Camaro SS 396/375 4K
Old 10-15-2025, 05:51 PM
TimG TimG is offline
I’ll post some photos later today, I’ve done many of them and always access through the bottom.
The Following 5 Users Say Thank You to TimG For This Useful Post:
1967 4K (10-15-2025), Carleen (10-15-2025), mhm1966 (10-15-2025), olredalert (10-15-2025), Tommy Nolen (10-15-2025)
Old 10-16-2025, 12:49 PM
Maybe you have found a new calling in life?
Paul
Old 10-15-2025, 06:28 PM
I gutted an R-59 and put a Braille battery inside. See post #18 here:
https://www.yenko.net/forum/showthre...battery&page=2
That has been six years. I put a tender on it every few months. Usually shows full charge within just a couple of hours. It cranks great.
Old 10-15-2025, 06:54 PM
Here is what you are dealing with if you remove a core battery from a Restoration Battery. It can be done without removing the top and this is my preferred way of doing it. You can access the terminals.
The Following User Says Thank You to TimG For This Useful Post:
X66 714 (10-15-2025)
Old 10-15-2025, 06:59 PM
Here is what you are dealing with if you have to remove the guts from an old acid filled Restoration Battery or a vintage battery. This was an original R59 that never had acid put in it. Be careful if you core a battery, the case sides are fragile once you remove the internal plastic dividers. I know of one friend that broke the side out removing the lead plates and the battery was useless.
dykstra (10-15-2025), juliosz (10-15-2025), olredalert (10-15-2025), RPOLS3 (10-15-2025), X66 714 (10-15-2025)
Old 10-15-2025, 09:56 PM
Tim
What tool/tools did you use to cut out the bottom of the Restoration battery with?
Old 10-15-2025, 11:27 PM
I drilled multiple holes and came back with a hand saw. The battery originally set in the case is so close to the side of the case it's hard to get a saw between the two. It's really a nasty job, especially with an acid filled battery.
Old 10-16-2025, 12:08 AM
^ Thank You.
