Old 09-11-2025, 03:04 PM
DougsL78 DougsL78 is offline
Default 68 Nova leaf spring question
Hey guys,
The 5 leaf leaf springs here are for sure the factory ones that came with my ‘68 L78 nova as the drivetrain is original to the car…
While restoring, I noticed a difference in the angle of one of the bushing holes. See picture below. One is more ‘kinked’ than the other. There is no evidence of any damage and it’s smooth.. so my question here is whether this is a “68 Nova-ism” - god knows nearly every single part of the car is…. Or is this damaged and should not be restored/reused?
I figure if it was damaged it would be crunched- and there would be damage in and around it -which there wasn’t - it was 100% solid and original - and the springs looked like they had never been off the car…. But I’ve never seen a set of leaf springs on a Nova that were not identical….
Thanks all!
Attachments - The Supercar Registry IMG_7985.jpeg IMG_7983.jpeg IMG_7982.jpeg IMG_5322.jpg
Old 09-11-2025, 04:19 PM
69W314spd 69W314spd is offline
5 leaf pack off my 69 shows the same
The Following User Says Thank You to 69W314spd For This Useful Post:
DougsL78 (09-12-2025)
Old 09-11-2025, 04:27 PM
Thanks - that’s super interesting…. I didn’t pay attention taking them off (I didn’t expect a difference).. so if they are different, is there a dedicated right/left? What side is the ‘extra bend’ meant for (and more interestingly, why??)
Old 09-11-2025, 08:45 PM
luzl78 luzl78 is offline
the mighty torque of the l78.
Old 09-12-2025, 02:51 PM
big gear head's Avatar
Slapper bars bend springs when they are not long enough to hit directly under the bushing. If I remember correctly Lakewood was too short. We used Competition Engineering on my brother's '70 Z28 because they were the correct length.
Freddie
1967 4K (09-12-2025)
Old 09-12-2025, 03:21 PM
these are at the rear hangars not the front, have you seen it bend the rear?
Old 09-12-2025, 03:25 PM
I guess my question is - is this one bent or is it as designed? Should I be sourcing replacements? 69W314speed’s picture being the same is interesting and gave me hope I didn’t have to source another set.
Old 09-12-2025, 03:48 PM
L78_Nova's Avatar
L78_Nova L78_Nova is offline
The rear eyes have the leaf centered to the bolt.
The front eyes have the leaf offset to the bottom for spring clearance to the subframe/mounting bracket.
I believe the OP has one rear side different to the other rear side which is probably not correct, just bent or mis-shaped a little. I don't believe there are specific LH RH fitd.
70 Chevelle SS-454 LS-5 M-22
Old 09-19-2025, 04:59 PM
So, usable? Or should I be sourcing others? There aren’t many (any?) repro ones that are correct so that may be a difficult task for the proper restoration…
Old 09-19-2025, 08:41 PM
L78_Nova's Avatar
A good spring shop could match those ends up.
But I would almost install them first to check ride height so you know if you're happy with them.
Gary
The Following User Says Thank You to L78_Nova For This Useful Post:
Too Many Projects (09-20-2025)
