Old 08-03-2025, 08:48 PM
lpar1969 lpar1969 is offline
Yenko Premier Member
Default Firewall Wire
I was wondering if anyone knew where the taped wire pictured on the firewall leads to
Old 08-03-2025, 09:12 PM
Year, make, and model would be helpful.
Bill Pritchard
Old 08-03-2025, 09:21 PM
1969 Camaro Z/28
Old 08-03-2025, 10:28 PM
thehornworks thehornworks is offline
Cowl hood flapper?
Old 08-03-2025, 10:48 PM
Originally Posted by thehornworks View Post
Cowl hood flapper?
I think so as well, Car is an original ZL2 option.
Old 08-12-2025, 11:55 AM
dykstra's Avatar
dykstra dykstra is offline
Hope this helps
Dave Dykstra
NCRS#66003
Dykstra Motorsports
Old 08-12-2025, 01:21 PM
You sure it isn't the tach wire? Cars with U16 Tachometer (not the full gauge package U17) got an extra hole drilled just above the fuse block for the tach wire. That means it also would have a center fuel gauge.
Old 08-12-2025, 02:48 PM
Lynn
I do have a Center Fuel Gauge. I also have the ZL2 Hood Option. As strange as this gets, I have a Gauge Harness underneath dash which I assumed was for Console Gauges
Lou
Old 08-12-2025, 03:13 PM
X66 714's Avatar
X66 714 X66 714 is offline
If you have center fuel gauge, you won't have console gauges. Your under dash harness should have a orange/white for the light at the back of the console. not sure what else was in that harness except maybe a ground on a 4 speed car. The picture you take this evening will tell the rest of the story....Joe
lpar1969 (08-12-2025)
Old 08-12-2025, 03:48 PM
Somewhere along the way someone attempted to put in console and gauges.
Only the U16 gauge package received that hole.
lpar1969 (08-20-2025)
