Old 05-26-2025, 08:00 PM
1967 4K's Avatar
1967 4K 1967 4K is offline
Default 346 brake master cylinder, W T stamp?
My 30 year old repop power disc brake master cylinder has bit the dust. I want to replace it with a GM correct 346 unit. My cars build date is first week of June 67. Should the unit have the W T stamp on the front pad or is it okay to not be there?
I have found them both ways, I was always under the impression that all used on a power disc brake cars had the W T stamp.
I’ve got a message into Mike Gibbons but today being a holiday I don’t expect a return message until later.
Richard
1967 Camaro SS 396/375 4K
Old 05-26-2025, 08:39 PM
X66 714's Avatar
X66 714 X66 714 is offline
WT is the correct master cyl for 1967 & 1968 with power disc brakes. I've seen several but I think it was determined that there was no date code in the casting. I would look for one with WT stamped. Mike can get you going in the right direction....Joe
1967 4K (05-26-2025)
Old 05-26-2025, 09:48 PM
luzl78 luzl78 is offline
All power disc 67 Camaros had the wt on the master.
Old 05-27-2025, 12:02 AM
1967 4K's Avatar
I’ve been wanting to do this change for a long time and had researched this before. I wanted to hear what you guys thought. CRG says the 67 power disc brake Camaros had the W T stamp.
Seeing the 346’s without the W T kinda threw me off. Appreciate it guys.
Richard
Old 05-27-2025, 01:30 AM
Replacement master cylinders didn’t have the wt markings.
1967 4K (05-27-2025)
Old 05-27-2025, 02:28 PM
1967 4K's Avatar
That’s what I had suspicioned, the ones without WT were replacement units.
Richard
Old 05-29-2025, 03:13 PM
jl8z28 jl8z28 is offline
Good price
Old 05-29-2025, 08:25 PM
1967 4K's Avatar
Barry, I sent you a PM couple hours ago.
Richard
Old 06-29-2025, 11:19 AM
1967 4K's Avatar
Default WT stamped 346 PDB MC
I received my 346 WT stamped power brake master cylinder from Mike Gibbons Friday. His service is second to none! He helped me from identifying a correct one to the bleeding process.
For you guys looking for a correct PDB master cylinder for your 67 or 68 Camaro do your homework for they are being fake stamped and other things. Call Mike he’ll help ya out.
Richard
The Following 8 Users Say Thank You to 1967 4K For This Useful Post:
69M22Z (06-29-2025), Billohio (06-29-2025), dykstra (06-30-2025), olredalert (06-29-2025), ragtop (06-29-2025), RobR (06-29-2025), RPOLS3 (06-30-2025), X66 714 (06-29-2025)
