Old 02-06-2025, 10:11 PM
jkhall316 jkhall316 is offline
Default I have a 1970 RS/SS camaro.. qusetion about TRIM Tag
The trim tag on the firewall has something that I am questioning.
The 3rd row from top middle has "454504" identified in there. The only thing that comes up on the net about this is the Baldwin Motion swapped 454504 options.
Is there any evidence that Baldwin noted this option on the trimtag for 1970 Camaro's?
Old 02-06-2025, 11:02 PM
GotGrunt's Avatar
GotGrunt GotGrunt is offline
I’m going to assume you have a Los Angeles built Camaro. Those numbers in the 3rd row (aside from the build date) are just data processing numbers found on the build sheet.
Old 02-07-2025, 12:35 AM
No.
Bill Pritchard
Old 02-08-2025, 04:40 PM
Tracker1's Avatar
Tracker1 Tracker1 is offline
Trim tags were stamped at the Fisher body plant. It's a Fisher Body processing number as Grunt has indicated. Aftermarket modifiers had nothing to do with trim tags - so double NO.
I ain't nobody, dork.
