Old 01-17-2025, 04:23 AM
Default How to Remove Glued Gasket from Air Cln Lid
Wanting to rechrome 17" GM Air Cleaner Lid (70 Z28 & Big Block Also)
Anybody have advice on how best to loosen glued gasket without damaging????
Thanks
Chuck Sharin
[email protected]
70 Camaro R/S Z-28, L-78
69 Camaro COPO recreation
Old 01-17-2025, 10:54 AM
69L78's Avatar
69L78 69L78 is offline
use a hair dryer to heat it up, then use a razor blade to peel the gasket off. Practice on a label from any package you have to see how easy it is, just take your time.
Old 01-17-2025, 12:42 PM
mhm1966 mhm1966 is offline
Once you heat the gasket and are able to start to peel the gasket up a solvent like prep-sol will expedite the process.
Old 01-17-2025, 12:59 PM
Try a crayon..
The Following 5 Users Say Thank You to Mr70 For This Useful Post:
169indy (01-17-2025), 69PostSSChevelle (01-17-2025), bergy (01-18-2025), dykstra (01-18-2025), SuperNovaSS (01-20-2025)
