Old 07-20-2024, 09:35 PM
Harvey Harvey is offline
Default Holley Base Plate Number for List 4491 Carb
I have a 1970 L-78 Nova (California car) and I am searching for the correct base plate number or complete carb. Any information would be helpful. Thanks in advance.
Old 07-21-2024, 04:58 AM
John Brown's Avatar
12R-4594A is the throttle body and shaft assembly, according to Holley Illustrated Parts & Specs Manual dated 1975.
Holley may have changed their numbering system since then, but at least this should give you a place to start.
John Brown
Old 07-21-2024, 03:12 PM
Thanks for the reply.
Old 07-24-2024, 11:00 PM
Copperl654spd Copperl654spd is offline
1970 California NA9 Holley Carb bases are embossed with Holley part number 12R 4506 and have extra vacuum port tube on front pass side of base.
Need to pull off front bowl to see the part number on the front of the base.
Fed carbs are embossed12R 4506B on front of the base.
Copperl654spd
The Following User Says Thank You to Copperl654spd For This Useful Post:
John Brown (07-27-2024)
Old 07-26-2024, 02:00 PM
Thanks for the updated information. Happy I have the correct base for the NA9 carb.
