Old 01-23-2024, 09:59 PM
slimsls6 slimsls6 is offline
Default speedo cable routing
Hi everyone. what is the correct way to route the speedo cable on a 70? Kansas car. above or below trans? I have mine above but don't think that is correct
TIA
*70 LS6 M-22, unrestored, original born with, special ordered orange.
* 72 nova 557ci, LGT700 5 speed, AFR heads
, Tunnel ram W/ dual 750's, 723hp/690tq, 2 1/8 Lemons
Attachments - The Supercar Registry MR's previously owned CS LS6.jpg IMG_7418 1.JPG 12074522_1036346599731283_4066217439499161344_n.jpg
Old 01-23-2024, 10:24 PM
Underneath. David Beem photo of his previously owned survivor LS6.
The Following 6 Users Say Thank You to SS427 For This Useful Post:
69M22Z (01-24-2024), dykstra (01-24-2024), olredalert (01-24-2024), RPOLS3 (01-26-2024), slimsls6 (01-24-2024), Xplantdad (01-24-2024)
Old 01-23-2024, 10:29 PM
does it go in a clip on the trans or just the body clip? I'm not sure if I have the one on the floor board
? Thanks Rick
Old 01-24-2024, 03:23 PM
In most cases you will have two clips on the floor. I believe the location somewhat depends on the manufacturing plant and transmission type. The bracket that mounts on the transmission to bellhousing bolt was not used on the LS6. The first photo is where the Leeds plant (same as your car) attached the clips on an M22 car. The second is the bracket that was used in 69 per Chris White.
The Following 7 Users Say Thank You to SS427 For This Useful Post:
dykstra (01-26-2024), enio45 (01-24-2024), L78_Nova (01-24-2024), olredalert (01-24-2024), PeteLeathersac (01-24-2024), RPOLS3 (01-26-2024), slimsls6 (01-24-2024)
Old 01-24-2024, 04:50 PM
enio45 enio45 is offline
Always great info from Rick!
Eddie M
Camaro-less
87 El Camino SS
Few Ferrari's
