Old 10-29-2023, 01:49 PM
Default Hone O Drive
Does any one which gear lube should be used in the Hone O Drive?
Thanks Dan
Old 10-29-2023, 02:21 PM
Lee Stewart's Avatar
I believe it's GM dexron automatic transmission fluid.
Old 10-29-2023, 02:34 PM
Too Many Projects's Avatar
Found this pic and it does look like it's auto trans fluid. hard to read if it specifies Dexron... maybe someone can enlarge it.
Mitch
1970 Chevelle SS
1966 Chevelle SS
1967 Camaro ss/rs
Old 10-29-2023, 02:37 PM
As a side note, these were originally built only for Ford applications, so it may want FOMOCO fluid ? The 300 universal model came along well after the initial introduction, so I would believe the lube requirements would be the same as the earlier Ford models...
Mitch
1970 Chevelle SS
1966 Chevelle SS
1967 Camaro ss/rs
chevyandpontiac (10-30-2023)
Old 10-29-2023, 03:28 PM
SS69chevelle SS69chevelle is offline
The 300 hone o drive instructions i have identify one quart of ATF automatic transmission fluid and refers to instruction 11.
instruction 11 reads; "Fill the HONE-O-DRIVE with 1-3/4 pints of Automatic Transmission Fluid. Never allow oil level to be more than 1/8" below oil fill hole. Check level at each engine oil change, and watch for possible seal damage at both ends."
Hope this helps take care Andy
Andy
Team Chevelle #3135
ACES #08305
1969 Chevelle Trim Tag Research (On-going)
The Following 2 Users Say Thank You to SS69chevelle For This Useful Post:
chevyandpontiac (10-30-2023), COPO (10-29-2023)
Old 10-29-2023, 05:39 PM
Yes, it is ATF. I'm not sure it matters if it is Dextron or Motorcraft since there are no clutches to be concerned with.
The Following 2 Users Say Thank You to SuperNovaSS For This Useful Post:
chevyandpontiac (10-30-2023), L_e_e (10-29-2023)
