Old 08-14-2023, 01:23 AM
70LS6454 70LS6454 is offline
Default Pair of M&H MSS001 MuscleCar tires 275/60B15
Pair of M&H MSS001 Muscle car series tires 275/60B15. These are new. I had these mounted. They would not fit on my car. I couldn’t jack the car down off the jack stands. I took the wheel right back off.
They are currently on back order through most vendors again.
$650 picked up.
Ray
Attachments - The Supercar Registry IMG_0600.jpeg IMG_0327.jpeg E6FB291C-E084-4EB3-B91C-69159A448EC0.jpg D5AB016C-D573-461A-A0CF-A098F66991F1.jpg
Old 08-14-2023, 02:52 AM
Would not fit your LS6 454? A different car?
Should have no problem if you have the right offset on your rear tires. I have 275 60 R15 on the back of my 68 El Camino, and they have never rubbed, even when towing; and I tow a lot.
Tried the same size tire on my 69 Camaro in and M & H street slick, and even though they did not hit anything sitting still, I was afraid to drive it, as it was SOOOO close in a couple of spots. Couldn't risk ruining my new paint job.
Old 08-14-2023, 03:37 AM
luzl78 luzl78 is offline
If a 70 chevelle, you need a 15x8 wheel with a 12mm(5”) backspace. That would be perfectly centered with the 275/60-15 tire.
Old 08-14-2023, 05:25 AM
Hey Guys. Yes these were for my 70 Chevelle. They were mounted on a set of older Cragars. Currently I do have BFG 275 60 15 radials on 15x8 Weld wheels with 4 1/2 back space. They fit fine even with the old sagging springs, The older Cragars are 15x8 with 4 1/4 back spacing. Honestly though the M&H”s are a good inch wider and taller than the radials. M&H (Left) Radial (Right)
I was going to try the Pro Trac 275”s which according to their description are slightly narrower than the BFG radials
Ray
The Following 2 Users Say Thank You to 70LS6454 For This Useful Post:
dustinm (08-14-2023), jerry455 (08-16-2023)
Old 08-14-2023, 02:51 PM
Was wondering if that might be the case.
Old 08-16-2023, 11:59 PM
VintageMusclecar's Avatar
I tried a pair of those on my `67 Chevelle mounted on a pair of Centerline AutoDrag 15X8.5" wheels with 4.875" backspace and they hit both inside and outside wheelhouses.
After doing some measuring, I found them to be almost 1" wider in section width than advertised, so they came off and I went with a pair of Hoosiers in the same size. Fit like a glove. A friend has the M&H's now for his `71 GTO street toy.
The Following User Says Thank You to VintageMusclecar For This Useful Post:
dustinm (08-17-2023)
Old 09-28-2023, 10:38 AM
3X24SPD 3X24SPD is offline
Surprised you couldn't fit those. I run a 28X12 Mickey Thompson on the back of my '66 GTO on a 10" rim with 5.5" of BS.
Nice looking tires OP. GLWS
Old 10-01-2023, 01:09 AM
I would have to raise my car approximately 4 inches to get these to work with my Cragars.
Old 08-17-2023, 11:13 AM
69 Post Sedan's Avatar
I run these on my ‘69 with no issues but I obviously have the rear raised from stock. They have a 10” wide patch and an 11.7” section width. The rear wheels are 15x8 with a 4.25” backspace. I personally love them…..they’re DOT approved, look the part and hook at the track along with on the street.
GLWS
Kurt
1968 Schwinn Orange Krate
1969 Schwinn Pea Picker
1968 Schwinn 5-Speed
1970 Schwinn 3-Speed Deluxe
1973 Schwinn 5-Speed Suburban
All Original Paint Bikes
The Following 7 Users Say Thank You to 69 Post Sedan For This Useful Post:
69M22Z (08-17-2023), Big Block Bill (08-17-2023), chevyman0429 (08-17-2023), dustinm (08-17-2023), L78_Nova (09-28-2023), napa68 (08-17-2023), RPOLS3 (08-17-2023)
Old 09-28-2023, 12:34 AM
Just bumping these back up.
