Can anyone id this cam by these numbers?
I was told it is a GM LS-7 cam 1068 main numbers off to the side 9181 thanks for any help. Dan |
Is it this cam from a couple years back or if not but same #, the participating Members may have info… https://www.yenko.net/forum/showthread.php?p=1558884 ![]() ~ Pete .
I like real cars best...especially the REAL real ones! |
Lots of hits Googling indicate 9181 is ZL1 Factory Part # 3959180. Below specs w/ L88 comparison from Post 15 @ this link… https://www.camaros.net/threads/pain...8-motor.86841/ ![]() ~ Pete . L-88 427 430 HP Solid flat tappet 354° int 0.562" int (Advertised) part # 3925535 360° exh 0.584" exh Duration @ .050 Int./Exh. 264 / 269 Degree Lobe Separation 112 Lash Hot Int./Exh. .024 .026 RPM operation 4400-7000 Open/Close @.050" Cam Lift Int./Exh. 24**** 60 70.5** 18.5 ZL-1 427 Solid flat tappet 262° int 0.580" int @0.050 lift part # 3959180 273° exh 0.620" exh Lobe separation angle 110°, lobe centerline 106°/114° Intake opens/close 52 BTC/95 ABC, Exhaust 94 BBC/59ATC .
I like real cars best...especially the REAL real ones! Last edited by PeteLeathersac; 04-13-2023 at 11:28 PM. |
| The Following User Says Thank You to PeteLeathersac For This Useful Post: | ||
chevyandpontiac (04-14-2023) | ||
