Old 05-29-2022, 11:57 AM
CanCOPO CanCOPO is offline
Default Shifter Linkage Bolts
The bolts going into my Muncie holding the linkage on keep backing out. These are original and no issues with wear. I torque them, tried loctite and every 4 or 5 months they back out. Any advice would be very much appreciated.
1969 Hugger Orange RS COPO (Sold)
1969 Garnet Red Z28
1969 Super Bee (Sold)
1965 Pontiac Lemans
Old 05-29-2022, 12:49 PM
Consider putting safety wire around them,like the Aviation field does?
NorCam (05-29-2022)
Old 05-29-2022, 03:56 PM
napa68's Avatar
napa68 napa68 is offline
Are they the bolts holding the arms to the shift forks or the shifter to the tail shaft?
Old 05-29-2022, 05:57 PM
rszmjt rszmjt is offline
If its the shifter tag bolts you are talking about- do they have the thin flat washer and lock washer on the bolts? Also do the tags fit tight on the trans shifter arms?
if the slots in tags are worn they try to rock forward and backwards when shifting which constantly work at trying to loosen the bolts.
