Old 04-08-2022, 03:07 PM
napa68's Avatar
napa68 napa68 is offline
Default Cleaning rust pits / road rash from paint
I am working on the 68 Camaro I just bought back. The bottom of the car is most all original paint (this is an LA car). I am guessing where the rust accumulation is where paint was very light if not non existent. As pictured, there is also road rash in spots that I'd like to improve on.
I have tried buffing compound with a couple of different pads and had a minor improvement. I feel it could be better.
These are a couple of pics where I have not touched anything....
Here is where I have been buffing....
I saw this video a while back and at the 5:19 mark, they speak of using an acid solution that naturalizes the rust in those pits. Has anyone does this and what is the magic brew?
Any other suggestions? I'm all ears.
In advance, thanks!
Tim
Old 04-08-2022, 04:42 PM
Formula455SD Formula455SD is offline
Wire wheel cleaner and a wet toothbrush.. like Eagle One brand or something similar.
Old 04-08-2022, 05:36 PM
169indy's Avatar
169indy 169indy is offline
What about NJ Steve's Evapo Rust Kiddy Pool (Basin) and Fish tank pump and sprinkler set up on the rear qtr?
69 Los Z11
68 SS/RS 396/325
68 Los Z28
Old 04-08-2022, 05:58 PM
napa68's Avatar
I had given that some thought as well. When I saw that video, it really got my attention.
Old 04-08-2022, 06:53 PM
67since67's Avatar
Muriatic acid. A great share of the top side of the '67 Chevelle Concours wagon I just finished was peppered with surface rust specks due to thin paint.
Apply to a small area, wait a few, neutralize with water and wipe off. follow with what ever buffing you want to do, then most important, a good wax, like Collinite 845.
Bill W
The Following 8 Users Say Thank You to 67since67 For This Useful Post:
chevyman0429 (04-08-2022), dustinm (04-09-2022), L78_Nova (04-11-2022), napa68 (04-09-2022), NorCam (04-09-2022), RPOLS3 (04-09-2022), scuncio (04-11-2022), Xplantdad (04-08-2022)
Old 04-09-2022, 03:14 AM
169indy's Avatar
Also, Dannystar used a system on the Butternut Yellow 68Z28 that was pimply and rusty, I do not remember what he used tho.
69 Los Z11
68 SS/RS 396/325
68 Los Z28
Old 04-10-2022, 02:58 AM
Canuck's Avatar
Canuck Canuck is offline
He soaked rags in evaporust and let them sit on the rusty surfaces.
www.vancouverclassiccars.com
The Following User Says Thank You to Canuck For This Useful Post:
hogdaddy (04-10-2022)
Old 04-10-2022, 05:12 PM
thehornworks thehornworks is offline
https://www.ebay.com/itm/38470257340...53.m1438.l2649
I use this... the best .gary
Old 04-09-2022, 06:44 PM
I have used muratic acid and then a solution of baking soda and water to neutralize the acid, followed by Meguires #7,
You could try citric acid first which is a good bit weaker.
Old 04-10-2022, 01:12 AM
SPEEDYB SPEEDYB is offline
Its hard to do but its best just to leave it as is,
your job now is to keep moisture away from the car
and the environment that the car is keep in dry.
Thats preservation.
