Old 03-26-2022, 04:56 AM
169indy's Avatar
169indy 169indy is offline
Default 1100843 0E11 Alternator
I have a nice 1100843 0E11 for 1970 Chevrolet. Unit spins Rebuilt, & Tested w/ proof. freely and works. I rebuilt using new parts from a Kit and cleaned and reinsulated (John C Dolph Air Cured (AC41) insulating varnished the Rotor and stator windings. Groomed the Case to give a nice fresh appearance. 61amp version. I had the fan and pulley zinc plated. I took the ALT to local Autozone and tested SAT, do not be concerned about the 1.9field amps tagged as unsat, we pulled two NEW alts from Autozone shelf and they tested same results. One Diode has press mark that is not affecting function.
$100 plus the ride, doubleboxed.UPS (Paypal F&F)Please
Thanks
Jim
69 Los Z11
68 SS/RS 396/325
68 Los Z28
Attachments - The Supercar Registry DSC02944.jpg DSC02943.jpg DSC02942.jpg DSC02941.jpg
Old 03-26-2022, 05:34 AM
McCune McCune is offline
It needs a Delco fan on it. It has a 10 blade Motorcraft (Ford) fan on it. I can help with a fan if you can't locate one.
Old 03-26-2022, 08:46 PM
169indy's Avatar
I appreciate the Help, I dug in the part bin and found what I think is the Orig Fan from this unit, got swapped during plating parts bag sorting. New Photo added of Fan & pully attached.
69 Los Z11
68 SS/RS 396/325
68 Los Z28
The Following User Says Thank You to 169indy For This Useful Post:
McCune (03-27-2022)
