Old 11-18-2021, 05:42 PM
F41427 F41427 is offline
Default 454 SHP 4 bolt main std bore
1978 date 454 with the large oil boss above the filter. The block was just cleaned magged no cracks then shop peened. The caps were bead blasted. Notice The casting numbers were stamped backwards from the factory. Comes with choice of GM Dimple rods pressed or floaters.
The Machine shop said the bores will clean up at .020. That is all the work I had done. Same foundation as the LS6 blocks just different casting number and date. No vin stamp present. I do have the windage tray bolts just not pictured. This is a super clean solid block to have built and hard to get std bore still. $2,500
Attachments - The Supercar Registry 20211117_162101.jpg 20211117_162054.jpg 20211117_162041.jpg 20211117_162027.jpg
Old 11-18-2021, 09:20 PM
luzl78 luzl78 is offline
Do the cylinders have to be machined?
Old 11-18-2021, 10:08 PM
Default 454...
from the ad...
The Machine shop said the bores should clean up at .020.
Old 11-18-2021, 10:16 PM
Originally Posted by WILMASBOYL78 View Post
from the ad...
Yea yea. Idiot me reads the ad too fast. Thanks for keeping me in the know.
