Old 10-08-2021, 01:42 AM
Too Many Projects's Avatar
Default What did you work on today ?
Another forum I've been on for several years has one of these threads that has been running for about 7 years. Thought I would post what I have been doing the past few days at work.
1968 Mustang that had rust holes thru the frame rail ahead of the apron. Manager told the owner we could "slip" a new rail in. He ordered a complete rail and it was sent to me in the back room. I told him the first thing we need to do is pull the engine/trans. "Say what, can't you levitate them to replace the rail"? Um, no, this is a unibody and the rail is spot welded to the apron from the inside...where the engine is...
Anyway, I removed the lower suspension but had to wait for the owner to get a new spring compressor, as someone had misplaced, or "borrowed" it and no on could find it in the building. After removing the drivetrain, I started drilling out the spot welds and removed the rail ahead of the shock tower. I had to cut open the outer rail at the tower, as there was ONE spot weld that wasn't accessible from the engine bay and that area was right behind the upper control arm.
I then moved to the rear of the rail and analyzed the cobbled, patch job back there. Someone had been in there and replaced the torque box and toe board but only patched the rail and not all that well either.
I needed to get the patch out of the way to access the flange on the torque box to rail, so I cut that out.
Oh, yeah, nice patch job...
I cut the TB in half to access the rear of the rail that is SUPPOSED to have a weld flange at the toe board to drill out the spot welds, but the patch didn't have the flange... Oh well, the emplacement rail does, so I still needed to get in there to weld the new one in.
The new spring compressor came the next morning, so it took all of 2 minutes to get that out. MAN this new tool is way better than the worn out old one !!
Finished drilling the rest of the spot welds and removed the debris. Any of you Mustang guys notice what else the previous patcher didn't do with the replacement frame extension ?
Did a test fit and tweak with the new rail and marked all the spot weld holes to remove the EDP.
THIS is the flange that should have been on the previous patch.
I was able to get the 2 oval alignment holes to match up very well, so knew it was far enough back.
The crossmember is a very precise part that keeps the distance between the rails accurate. It has tapered head bolts that when tightened, holds that tolerance. I was pleased that the member and bolts when right in without any forcing, or movement of the rail.
As of 3 pm, when my "day" is done, the rail and car are all prepped and the rail locked in place, ready for welding when I go back on Monday. I usually work Monday-Wednesday, but I had to skip yesterday to work with an excavator who cut out a spot in my yard and built a gravel pad for a new 12X16 shed, so I worked today to make that up.
The shed is my home project for the next week or so.
SO, what did you do "today" ??
Mitch
1970 Chevelle SS
1966 Chevelle SS
1967 Camaro ss/rs
The Following 5 Users Say Thank You to Too Many Projects For This Useful Post:
dustinm (10-08-2021), L_e_e (10-08-2021), PeteLeathersac (10-09-2021), RPOLS3 (10-08-2021), scuncio (10-08-2021)
Attachments - The Supercar Registry ZLift.jpg Zfuel pump wrench.jpg YZ100-1.jpg wrench.jpg
Old 10-08-2021, 03:40 AM
Today?
1. Attempted to find a gallon of paint to repaint my bathroom. Apparently paint is in short supply at some stores, like so many other things. I was finally successful at finding the brand and color that I wanted, but it wasn't easy.
2. Continuation of my attempt to get my sometimes-malfunctioning cell phone fixed. Massive circle-jerk. Hours on the phone and/or waiting for a callback from my provider (Consumer Cellular) or the phone insurance provider. Fruitless trips to a local cell phone repair shop and a local Consumer Cellular retail outlet.
3. Consume adult beverages in an attempt to forget the frustrations encountered with #1 & #2.
Bill Pritchard
The Following 5 Users Say Thank You to Bill Pritchard For This Useful Post:
Damien (10-09-2021), dustinm (10-08-2021), dykstra (10-11-2021), scuncio (10-08-2021), Too Many Projects (10-08-2021)
Old 10-08-2021, 04:59 AM
My cell phone ringer doesn't work anymore. I've stopped into a local "repair" place twice and been told they will order a new speaker and call me when it's in. Been 3 months since the first visit and 6 weeks since the second. I'm not hopeful that they will ever call.
Mitch
1970 Chevelle SS
1966 Chevelle SS
1967 Camaro ss/rs
Old 10-08-2021, 05:13 PM
jasonL78 jasonL78 is offline
I read your post and need the manufacture of that awesome spring compressor you showed a picture of!
Looking for the next project.
Old 10-08-2021, 06:57 PM
OTC from Summit. I think the shop owner said Jegs was a little less cost, but was 2-3 day delivery. We called Summit and they shipped it overnight from Talmadge at NO extra cost... I got it Wednesday morning.
And guess what ??? The other part timer that works on Thursday and Friday on the frame racks up front came in yesterday morning and the owner asked him about it. He had used the old compressor the week before and didn't put it back. We looked EVERYWHERE for that tool, but he had buried it under parts of the car he was dismantling for repair...
No big loss, that one is so worn out, it is dangerous. I had another Mustang spring come out of it several years back as I was setting it down on the floor to release it. Luckily, the spring flew across the whole shop and hit some racking and didn't hurt anything. I hated that old compressor so am glad I have a new one to work with.
Mitch
1970 Chevelle SS
1966 Chevelle SS
1967 Camaro ss/rs
Old 10-08-2021, 07:05 PM
MosportGreen66's Avatar
100% need the name of it...
Old 10-09-2021, 12:50 AM
https://www.summitracing.com/parts/otc-6494
Mitch
1970 Chevelle SS
1966 Chevelle SS
1967 Camaro ss/rs
Billohio (10-09-2021), jasonL78 (10-11-2021)
Old 10-09-2021, 01:58 PM
napa68's Avatar
napa68 napa68 is offline
Finished up some brake work on this Thunderbird......
The Following 4 Users Say Thank You to napa68 For This Useful Post:
dykstra (10-11-2021), markinnaples (11-08-2021), RPOLS3 (10-11-2021), Too Many Projects (10-14-2021)
Old 10-08-2021, 05:48 PM
Besides all the other cars we are working on, we took a break for a one owner, original owner 70 SS396 M20 in for a laundry list of mechanical repairs. Extremely nice original car. I located 2 buildsheets in the rear seat while putting in a package tray so that made the owner's day. We also replaced the tires with the correct restoration tire for those that may ask.
The Following 12 Users Say Thank You to SS427 For This Useful Post:
67since67 (10-08-2021), carnut4life (10-08-2021), Damien (10-09-2021), Daves70SS (10-08-2021), dykstra (10-11-2021), Lee Stewart (10-08-2021), MosportGreen66 (10-08-2021), PeteLeathersac (10-09-2021), RPOLS3 (10-08-2021), ruralrte66 (10-09-2021), Too Many Projects (10-08-2021), ZAPPER68 (10-10-2021)
Old 10-08-2021, 07:13 PM
tom406 tom406 is offline
I rotated the tires and successfully used 3M’s headlight refinishing (cut buff n chemical seal) kit on my 16yr old daughters recently acquired one owner low mile PT Cruiser GT.
The Following User Says Thank You to tom406 For This Useful Post:
Too Many Projects (10-09-2021)
