Looking for photos and dimensions of an assembly line 3844100AK alternator pulley. Bonus if you have one to spare.
What applications was this pulley installed?
The dimensions listed in the 7/1/1967 parts book were:
Outside diameter: 3-7/32" Shaft [hole] diameter: 43/64" Groove width: 1/2" I can only speak to 65-67 Chevelle usage, but this was the factory pulley on 65 Z16's and 66-67 L78's. It also came on the 62 amp "AC generator" option in 65 and for at least part of 66. Some assembly line pullies were stamped, some weren't. I do not know if that was a matter of two different suppliers (each supplying different assembly plants), or a timing matter. I can only say for sure that - the pulleys on Z16's (all built at KC) were not stamped, - I have seen some original 66 Chevelle L78 pulleys that were stamped and some that were not, and - so far I have never seen an original 67 Chevelle L78 pulley that was stamped. 65-67 Originals were all cad plated. Later NOS replacements are cad-dichromate or zinc-dichromate (the goldish colored plating).
Jeff Helms 65 Z16 Survivor 65 Z16 drag car 66 Chevelle L78 unrestored 67 Chevelle L78 unrestored 67 Camaro SS350 Survivor |
Thank you for the wealth of information. I ask because I have a 1967 Camaro L78 04D car and want to recognize the correct part when I see it. I would hope both stamped and unstamped pulleys would be correct with original cad plating for my Norwood built car.
This reminds me of how lug nuts were made by different manufactures... some with waffle pattern, some without, yet the waffle pattern seems to be the most "correct" and desirable now? Is this the case with a stamped 100AK pulley? Last edited by jbtech; 09-16-2021 at 05:21 AM. |
It's also called out in the full size assembly manuals for '65 L78 and '66 L72.
Mark 1966 L72, 4spd Caprice 1974 Z28, M40 Camaro |
If it was a timing thing, then I would say unstamped is more likely correct. As I said above, I have never seen a verified original 67 Chevelle L78 pulley that was stamped. Here's my Baltimore July built original, as found before the car was awakened from a 37 year garage slumber.
| The Following User Says Thank You to jeffschevelle For This Useful Post: | ||
jbtech (09-17-2021) | ||
I have received photos of my original L78 04D engine as pulled in the late 60's early 70's by the original owner. The last photos are closeups of the alt and pulley now as provided by the current owners of the engine. The pulley is definitely a 3844100.
However it does NOT have a stamp but as previously discussed on CRG, later NOR cars appear to have a stamp. I include this data to prove early NOR L78 cars also used the 3844100 as illustrated in the AIM. Perhaps leftover pulleys were used from Chevelle production for early cars? Jose |
| Tags |
| 1967, alternator, l78, pulley |
