Old 08-30-2021, 08:02 PM
Default 1111437 Distributor 1970 Chevelle LS6 454/450HP Dated 9L11 Awesome Survivor
This is a very nice survivor Delco Remy 1111437 distributor. The 1111437 distributor was used exclusively on the 1970 Chevelle LS6 454/450HP engine with both manual and automatic transmissions. This distributor is dated 9L11 which decodes as November 11th, 1969. This is the real deal.
This distributor is in very good original condition as shown. I did not do any cleaning to this unit, it is exactly as found. It has the original 530 CCW advance cam and MS 360 12 vacuum advance. The shaft spins freely with no binding and the vacuum advance moved the point plate and holds vacuum when sucked on. The original wire that goes to the coil is in good shape with the original connector intact. This is a very nice survivor distributor.
SOLD
Attachments - The Supercar Registry P8305616.JPG P8305615.JPG P8305614.JPG P8305613.JPG
Old 08-30-2021, 08:54 PM
chads454Ls6 chads454Ls6 is offline
Yenko Premier Member
pm sent
