Old 02-28-2021, 04:11 AM
cdn454LS6 cdn454LS6 is offline
Default Look 62 small miscellaneous 1969 camaro chevelle parts, nos & used
62 MISCELLANEOUS 1969 CAMARO, and 1970 Chevelle Parts, NOS and used.
If your interested in a item I can get you better Pic's.
All item prices + shipping.
#1- NOS bell crank bracket $18 sold pending
#2- Vacuum booster fitting $10sold pending
#3- NOS Door strikers no box $35 sold pending
#4- 2 Original spare tire wing nuts $12ea. sold pending
#5- Oil fill cap $10
#6- Fuel Y block and tubes for Holly carb great shape $30sold pending
#7- Ground and screw for 1970 chevelle $29sold pending
#8- NOS 1968-9 Chevelle emblem $29sold pending
#9- 2 Camaro door emblems $15
#10- Full set interior door panels screw and clip set $20
#11- NOS air cleaner elbow $14sold pending
#12- NOS door bumpers $12
#13- 4 exhaust manifold bolt locks $12
#14- 2 Original Tilt column levers $18
#15- 2 Original Carb throttle springs $15 sold pending
#16- NOS Gas Cap $29
#17- 10 pieces NOS Bell crank Parts $29 sold pending
#18- 2 NOS rear backing plate nuts $18 sold pending
#19- NOS plug in oil switch $10 sold pending
#20- NOS hood latch piece , nice phosphating. $12
#21- NOS ground strap with screws $9
#22- NOS Spindle nuts , washers, cotter pins $19
#23- Original heater hose clamp $15 sold pending
#24- NOS steering coupler bolt in unopened GM bag $10
#25- NOS console light $12
#26- 5 NOS 1970 chevelle ash tray springs GM # 331524 All 5 $20sold pending
#27- Spring Ring Battery cable covers, negitive & positive $20
#28- Original 837 Alt Boot , not cracked in mint shape $25sold pending
#29-Original L78 carb clip $35 sold pending
#30- Original Master Cylinder brake Bracket $15sold pending
#31 Original Licence plate screws in GM package $25sold pending
#32- Original Fan shroud and bracket bolts & clips $15sold pending
#33- 2 replated correct horn bolts $10 sold pending
#34- 3 Original Trunk wire clips for light. $10
#34- Original Emerg Flasher knob $10
#35- 4 Original emblem nuts in GM package $10sold pending
#36- Original Hood latch Bolts and clips nice shape $15 sold pending
#37- 1 NOS Lock Ferrale in GM bag 3830938 $8
#38- 1 NOS ALT spacer in GM Bag $8
#39- 2 NOS Distributor wires in GM Box $15sold pending
#40- 1 NOS Clock shaft key in GM bag $6
#41- NOS Hi perf heavy Duty High Torque Solinoid starter spring $12 sold pending
#42- NOS Delco 180 degree Thermostat $18 sold pending
#43- NOS Delco CT22-1 Throw out Bearing Low Horse 325/350 $25
#44- NOS Chevrolet Wrist Watch $15
#45- NOS GM box of correct tie straps All for $15sold pending
#46- Original Cowl induction Coil bracket with capacitor $18sold pending
#47- NOS Oil fitting for 396/427 with GM picking tag. $16sold pending
#48- Original Glove compartment bracket 1969 Camaro $8
#49- Original Blue Round Fuse relay under dash 69 Camaro. $10 sold pending
#50- Original Shift levers stamped 870 OUT $18 sold pending
#51- NOS Gas Cap 3931449 $25 sold pending
#52- NOS Throw out bearing Delco CT24AG 396/427 $18
#53- NOS 7 TR BOLTS and 2 carb bolts $10
#54- 1 only Used nice chrome 69 Camaro door handle no button. $14
#55- NOS Chevrolet desk Clock with lots of functions, comes in metal case. $20
#56- Camaro Emblem for dash grab handle plate, with GM # on back. $9
#57- Original BB Clutch fork rod and swivel $18sold pending
#58- 2 NOS small emblem nuts in GM package $6
#59- Original Air cleaner wing nut. $15sold pending
#60- Original Power Steering Cap $15
#61- 1 NOS 1970 Chevelle hood pin clip $18sold pending
#62- 4 NOS T BOLTS in GM packages $19sold pending
#63- Original 660 Thermostat housing , Base is nice . $20 sold pending
Attachments - The Supercar Registry IMG_5343.jpg IMG_5342.jpg IMG_5341.jpg IMG_5340.jpg
Old 02-28-2021, 10:21 AM
R68GTO R68GTO is offline
Interested in item 28. Sent you a PM.
Old 02-28-2021, 12:59 PM
302moz 302moz is offline
Default Number 39
I will take number 39 . Distributor leads pm sent
Old 02-28-2021, 01:10 PM
XXXGoldL34M20's Avatar
7,11,15,26,35,45,61
I'll Take above, Email Sent.
Old 02-28-2021, 02:09 PM
KNAPPY KNAPPY is offline
PM sent
Steve
67 Z-28
69 COPO Camaro
Old 02-28-2021, 02:21 PM
mhm1966 mhm1966 is offline
PM sent on item 6.
Old 02-28-2021, 02:41 PM
subyman99 subyman99 is offline
I’ll take #57
1969 Yenko Camaro Lemans Blue -muscatell sold new, second to last yenko made
1969 Bill Hunter yenko camaro
1969 Berger copo original paint 240 miles
Old 02-28-2021, 04:04 PM
427yenko 427yenko is offline
I will take number 30, master cylinder brake bracket.
Old 02-28-2021, 04:32 PM
I’ll take #46 also
Old 11-28-2022, 11:40 PM
Are these used originals or repops?
67 Z/28 Butternut Yellow
69 Z/28 Rally Green
69 Z11 Pace Car
2010 2SS RS Aqua Blue
68 Z/28 Lemans Blue
2019 Corvette Grand Sport
68 SS Lemans Blue
69 RS/Z28 Maroon JL8
66 Corvette Ermine White L75
