Old 02-21-2021, 12:00 PM
69L78's Avatar
69L78 69L78 is offline
Default Vintage Faux Alligator Skin 8-Track 24 Tape Case w/Tapes
This has 24 8-tracks included, I never played any of them, so I cannot guarantee they will play. The box is in good condition, but I do not have the key. I am not sure of value so I have to start somewhere. Artist's included, Alice Cooper, Rolling Stones, Grand Funk, Jim Croce, Deep Purple, Doobie Brothers, J Geils Band, Jethro Tull, Peter Frampton, Nazareth, Procol Harum, Lynyrd Skynyrd, Bad Finger, Crosby Stills & Nash, Simon & Garfunkel, Bee Gees, John Denver & America. America.
SOLD
Attachments - The Supercar Registry to be restored 8-tracks.jpg done 8-tracks.jpg D740384D-7A61-4F43-A79B-86F61B3FF240_1_201_a.jpeg 8D7B934D-5D7D-4A55-8084-379154A1A378.jpeg
Old 02-21-2021, 01:43 PM
Burd's Avatar
Burd Burd is offline
Nice. I had the same case.
It's only Orig once
waste all the rest.
1978 Y88
1995 Q45
Old 02-21-2021, 04:50 PM
Crush Crush is offline
Incoming pm
Old 02-21-2021, 05:50 PM
KevinW KevinW is offline
I still have and USE a similar case and 8-tracks 8-tracks can be repaired!
69 327 convertible (driver)
Old 02-22-2021, 12:10 AM
Too Many Projects's Avatar
Wow, when I opened the post, I thought you had stolen 1 of my cases, until I saw the artists... I do have a few of the same tapes.
Mitch
1970 Chevelle SS
1966 Chevelle SS
1967 Camaro ss/rs
Old 02-22-2021, 12:01 PM
RPOLS3's Avatar
RPOLS3 RPOLS3 is offline
Can you share who does this? I have a few that I'd like to try and repair. Thanks
Jake Dykstra
Dykstra Motorsports
Old 02-22-2021, 02:49 PM
Grim70 Grim70 is offline
Check Youtube. They are easy to repair. ** DO NOT PLAY THEM UNLESS THEY HAVE BEEN REPAIRED*** The original splice will break and the tape will wind up in the deck.
The other repairs are usually the foam breaking down.
There are a few places that stock the materials
The Following 2 Users Say Thank You to Grim70 For This Useful Post:
Crush (02-22-2021), RPOLS3 (02-22-2021)
Old 02-22-2021, 06:08 PM
Here is a link with some how to's: https://8trackheaven.com/collecting/repair-2/ Repair parts can be purchased on ebay or some other sites.
Basically, you first find out if it is a foam tape or a metal spring tape by looking at the tape end. If the roller is good, replacing the felt/foam and the foil is the first fix. Other issues can be a damaged roller or the tape is so tight it won't feed. Practice on a junk tape 1st to get a feel for it I have a bunch of easy listening/country tape to scavenge rollers from.
The metal spring types you can replace the felt pads if missing and inspect the roller without opening. I have had good luck in replacing the felt pads, then playing it with auto stop. This will stop the tape at the foil, so you can replace the foil. If the foil separates, then you have to open it up.
For the foam ones, you will having to open it first, replace the foam, then try to find the foil. I have had to close them, play them auto stop to find the foil and replace.
Some brands are easy to open, some brands (lear/ampex) are a bear to open. Sometimes the clips break and you will have to "masking tape" it together during the fix/test phase. Then superglue the corners
8-tracks suffer more when not played. They last longer if played regularly. I listen to them in my basement while working on car projects.
The Following User Says Thank You to KevinW For This Useful Post:
Too Many Projects (02-23-2021)
Old 02-22-2021, 06:41 PM
X77Z28MP X77Z28MP is offline
Unhappy
I didnt think they had much value I threw out two full boxes of tapes and those same cases oh well
69Z X77 03D Lamans Blue
Old 02-22-2021, 07:11 PM
Bummer
