Old 12-03-2020, 01:11 PM
632biscayne 632biscayne is offline
Default MAY 69 DATED 1969 CAMARO Z28 DZ 302 COMPLETE ENGINE w 3928186 3932472 1111480
You are looking at a rare opportunity to make your 69 Camaro Z/28 numbers matching. This is an original, complete, numbers matching 69 DZ 302 engine. This engine was removed from a 55 Chevy that recently surfaced at a storage unit auction. The 55 was built in the 70s. This engine was most likely pulled from a wrecked Z back in the day. It is surprising complete and an incredible opportunity to get a complete DZ for your car. Here are the #s and dates:
BLOCK > cast # 3970010, cast date E19 (May 1, 1969 for 69 model year).
BLOCK SUFFIX > DZ = Camaro 302 / 4speed / 290 HP
ENGINE ASSEMBLY DATE > V0520= FLINT MICH PLANT May 20
HEADS > cast # 3928186, cast date E169 (May 16, 1969 for 69 model year).
VIN# > appears to be 19N053487 or 19N?53487 or 19N058487
INTAKE > cast # 3932472
CARBURETOR > # 3923289-DZ LIST-4053, date 942 (2nd week of April) of 1969 for 69 model year)
DISTRIBUTOR > 1111480, date 8L4 (Dec. 4, 1968 for 69 model year)
While the dates on the distributor are a little early for a May dated engine, I am confident this were born with the engine. This 55 Chevy was parked in the 70s and what are the chances the distributor was replaced with numbers matching components 40+ years ago. The engine turns over by hand. The Bores are standard and the original pistons look great. Crank was checked and everything is still STD with the original 69 dated bearings. It is being sold as a core for rebuild. It has never been blown up or modified. Everything is original and DZ302 only only!!! You get it as pictured. You may also ask for a quote to have it professionally rebuilt. How much will the value of your 69 Z increase with this complete numbers and date matched engine. If you need it, do not let it get away. You may never find another opportunity like this. NOTE: Please do not ask me to part this out !!! Dave 570-527-3450 $14000
Attachments - The Supercar Registry dz-windage.jpg dz-top side.jpg dz-suffix.jpg dz-dist.jpg
Old 12-03-2020, 11:50 PM
x77-69z28's Avatar
The number after the N in the partial would be a 6.
Buddy
Old 12-04-2020, 10:54 AM
jl8z28 jl8z28 is offline
That date would be a 65 vin
