Old 09-18-2020, 04:40 PM
pattrus pattrus is offline
Default 69 Camaro RS Inner Fenders
Does anyone have the GM part numbers for 69 Camaro RS inner fenders? Also, how rare are NOS ones?
Pat
Old 09-18-2020, 05:19 PM
I have never seen an NOS RS inner fender for a '69 Camaro and I have actively been searching out parts for over forty years. So based on that, I would say they are rare.
I believe you can take standard inner fenders and punch out the hole size you need on the dimple marks to convert to RS.
Greenlee sells all the punch sizes so you can make it look factory.
The RS inner fender part numbers are 3945791 LH, 3945792 RH. Standard inner fenders are numbers 3935917 LH, and 3935918 RH
The 3945792 RS RH inner went discontinued on 7/80 and superseded to the standard inner fender. The LH RS went discontinued just prior to the RH side.
- Warren
The Following User Says Thank You to WorkinProgress For This Useful Post:
NorCam (09-18-2020)
Old 09-18-2020, 05:53 PM
X66 714's Avatar
X66 714 X66 714 is offline
There's still some good used one out there. I sold some a couple of years out....Joe
Old 09-18-2020, 06:27 PM
Thanks. I have to check the part numbers to see if someone put the holes in mine or if they are actually NOS RS ones.
Old 09-18-2020, 09:09 PM
Jonesy's Avatar
Jonesy Jonesy is offline
Even good used are hard to find. I have never seen an NOS pair either.I think Warren is right, you could only buy the NON RS ones and had to cut the holes.
Old 09-18-2020, 11:03 PM
L78 Fred L78 Fred is offline
I have NOS GM white tag RS Inners if anyone needs picts or reference info
Also have good used RS ones for same info
Not looking to sell as they are set aside for projects
I'll loan anyone a Greenlee punch stud and I'll check my Knock outs and hole saws for sizing to see if I have any that match up.
Fred
[email protected]
610-585-4155
WANTED:
The Following User Says Thank You to L78 Fred For This Useful Post:
enio45 (09-19-2020)
